Dimable LED Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2012, 12:13 PM   #1
Dimable LED switches
Having trouble finding a dimmable switch for my LED lit art lamp. Any suggestions? A Cooper 9530 doesn't work
Dallas97701 is offline   Reply With Quote
Old 11-15-2012, 12:20 PM   #2
Does the lamp have a dimmable driver? If not, no dimmer will be compatible.
LooseSCruz is offline   Reply With Quote
Old 11-15-2012, 03:21 PM   #3
Rewards Points: 77
HD and Lowes both sell LED dimmers manufactured by Lutron and Leviton. I have used both with success.
patented is offline   Reply With Quote
Old 11-16-2012, 03:56 AM   #4
dmxtothemax's Avatar
Rewards Points: 5,348
Your LED light will contain some electronic circuitry
to regulate the power to the leds.
This circuit might not be designed to be dimmable,
in which case no dimmer will work !
You must have both - dimmable power supply
and correct type of dimmer !
If you are really keen you might be able to replace
the LED driver circuit with a dimmable type.
But it will effect your warranty if you have any !
dmxtothemax is online now   Reply With Quote
Two 3-way switches, one acting as a master switch? Ler0y Jenkins Electrical 10 02-28-2012 12:01 PM
Replacing old switches RyanS2000 Electrical 4 09-11-2011 03:21 PM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-20-2010 11:12 PM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 06:19 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
