Digitial Timer In 3 Gang Box With (2) 3way Switches And 1 Single Pole..confused. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-09-2013, 05:30 PM   #31
BCS
Originally Posted by tfo411 View Post
I *think* i found the switch you have on home depots site.
The wiring is quite different from how a normal 3 way works, but it also looks like in section 3 of the manual, there are instructions for using this timer with an existing 3 way setup. There is mention of a "jumper" wire on the switch which you havent previously mentioned.
http://www.homedepot.com/p/Defiant-2...9#.Unk4ifnrzHs
This is the timer i was looking at.
It worked! Thanks for the help.
BCS is offline   Reply With Quote
The Following User Says Thank You to BCS For This Useful Post:
Philly Master (11-09-2013)
Old 11-10-2013, 07:05 AM   #32
Rewards Points: 79
Good to hear!!
tfo411 is offline   Reply With Quote
Old 04-11-2015, 08:14 PM   #33
lkc
Rewards Points: 2
I just wanted to send a thank you note to tfo411. We were trying to figure out how to correctly install the same digital timer and weren't having any luck. A quick Google search brought us to this forum. The directions worked like a charm!!! The information was much appreciated.
lkc is offline   Reply With Quote
Old 03-20-2016, 11:30 PM   #34
Rewards Points: 2
Re: Digitial Timer in 3 Gang box with (2) 3way switches and 1 single pole..confused.
Another thank you to "tfo411". Why they don't include the instruction to abandon one of the travelers is really frustrating. Switch works just like it should it took about an hour of frustration and Google searching to get it right. Thanks again.
Roger2k1ii is offline   Reply With Quote
Wiring to Replace Timer Switch with Single Pole Switch BusterT Electrical 2 10-26-2012 03:39 PM
Replacing single pole light switches with double pole bruce54 Electrical 43 04-15-2012 10:23 AM
Separate Single Pole Switches for Ceiling Fan Light and Fan Only estatehomes Electrical 19 01-13-2012 06:13 PM
single pole timer switch with 4 lines incoming billyjeenyus Electrical 1 09-18-2011 01:20 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
