Digitial Timer In 3 Gang Box With (2) 3way Switches And 1 Single Pole..confused. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-05-2013, 12:42 PM   #16
Rewards Points: 79
It is confusing because they only seem to mention one traveller.
tfo411 is offline   Reply With Quote
Old 11-05-2013, 12:45 PM   #17
BCS
So...should I just return it and get a different timer? Or, do you know how to wire it? Very strange.
BCS is offline   Reply With Quote
Old 11-05-2013, 01:14 PM   #18
Rewards Points: 79
Ok think i got it. It was throwing me off because it doesn't look like it functions like a normal 3 way. In reality it doesnt look like a 3 way switch on the line side is needed at all but,
Go to the line side switch. Connect the incoming power (constant power black), to the black of your 3 conductor cable AND the common screw of your switch.
Connect the white from the incoming power cable, to the white of your 3 conductor cable.
And finally connect the red in your 3 conductor cable to one of the traveler terminals on the switch.
Now go to the load side timer.
connect the black in the 3 conductor to the black on the timer.
connect the white in the 3 conductor to the white on the timer.
connect the red from the 3 conductor to the red on the timer.
I believe that should do it.
Old 11-05-2013, 01:38 PM   #19
Oso954's Avatar
Rewards Points: 1,636
You are guessing. That's not good with electrical.
Way back, Eastcoastsparky said it looked like a dead end 3way.
That existing wiring needs to be confirmed (or corrected) before giving any wiring instructions.
This is what a dead end 3 way looks like (grounds omitted)
Digitial Timer in 3 Gang box with (2) 3way switches and 1 single pole..confused.-de3way.jpg
Oso954 is online now   Reply With Quote
Old 11-05-2013, 01:50 PM   #20
Rewards Points: 79
You are right, the other switch does need to be confirmed. If it is a dead end then my wiring suggestions wont even be doable.
Things will change slightly if its dead end. Not drastically though.
Old 11-05-2013, 02:05 PM   #21
BCS
And if its a dead end which it just might be what would be the wiring instructions?
Old 11-05-2013, 02:21 PM   #22
Rewards Points: 79
If it is dead end, which after looking more closely at pictures looks like it very well could be. (you need to confirm this)
Then black wire from timer with the bundles blacks.
White wire from timer with the bundled whites
Red wire from timer to red wire on 3 conductor
blue wire on timer to black wire in 4th cable
white wire in 3 conductor cable will be abandoned. disconnect at both ends and cover with wire nut.
And obviously, green to ground.
Old 11-05-2013, 02:27 PM   #23
BCS
The only wires in the 2nd 3way switch are black, red, white and ground which are all connected to the current switch. Does that indicate dead end?
Old 11-05-2013, 02:28 PM   #24
Rewards Points: 79
Yes. Dead end.
Old 11-05-2013, 02:33 PM   #25
BCS
Yes. Dead end.
OK great, I'll give it a shot later today and report back.
Thanks.
So for the 2nd switch the jumper wire will be connected to the black wire which will go to the common nut and everything else stays the same (Line switch).
Old 11-05-2013, 02:35 PM   #26
Oso954's Avatar
Trial and error wiring can fry that timer.
Old 11-05-2013, 02:39 PM   #27
BCS
Thus the reason why I am asking here for those that are knowledgeable before doing just what I dont want to happen.
Old 11-05-2013, 02:40 PM   #28
Rewards Points: 79
Not sure why you think its trial and error. My wiring suggestion is based of the manufacturers diagram. (if you can call it that..more of a sketch)
If you disagree then by all means post a suggestion. I've been wrong before and could be wrong again. Take a look, post a suggestion.
http://www.homedepot.com/catalog/pdf...29c61b474f.pdf
Old 11-05-2013, 02:45 PM   #29
BCS
Ok... disregard my question above regarding the line switch connection. White will be disregarded in both switches per your instructions above.
Old 11-05-2013, 03:03 PM   #30
Oso954's Avatar
It was a warning in response to
"OK great, I'll give it a shot later today and report back."
You often only get one shot with an electronic device like this timer.
Wiring to Replace Timer Switch with Single Pole Switch BusterT Electrical 2 10-26-2012 03:39 PM
Replacing single pole light switches with double pole bruce54 Electrical 43 04-15-2012 10:23 AM
Separate Single Pole Switches for Ceiling Fan Light and Fan Only estatehomes Electrical 19 01-13-2012 06:13 PM
single pole timer switch with 4 lines incoming billyjeenyus Electrical 1 09-18-2011 01:20 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
