Digital Timer Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2006, 02:52 PM   #1
Technophobe
Unhappy
Digital timer problems
Hi all, i have 2 (maxi-jet 500) water pumps for the aquarium, both pumps work fine, however when i plug them into a digi timer.......it screws up at random time.....the clock goes nuts/ the timer setting clear ect, i've tried 3 different timers from 3 diff manufactrurers, and all do exactly the same thing, and it doesn't even matter whether i have one pump or two running on the same timer (which are rated to 3000wts anyway)
Whats going on??
do i need surge protection things or something???
can anyone help please i've had 2 floods so far and don't know what to do
Bazzer
bazzer is offline   Reply With Quote
Old 11-19-2006, 03:19 PM   #2
World famous jerk.
Can you post the manufacturer and models of the three timers that you've tried so far? It would be helpful, since we can try to see what they might have in common to be able to spot the failure mode.
mdshunk is offline   Reply With Quote
Old 11-19-2006, 06:36 PM   #3
Technophobe
One is from Micromark, one is from Uni-com, the third was one i already had and don't know the manufcturer.
I presumed it must be the load, but if i plug a standard lamp in they work fine, as soon as i plug the pump or pumps into it, it happens, but i have found nothing about the pumps that exceeds 3000watts
Heres a link to the pumps.......Maxi-jet 500's (x2)
http://www.3rlighting.com/html/3rlighting026.htm
Old 11-19-2006, 07:29 PM   #4
World famous jerk.
Ahh.... yes. Those pumps don't have enough load for solid state timers to work properly. If you read the instructions to a solid state digital timer, they do have a minimum required connected load for them to work properly. Add a light or something like that in addition to the pumps, and I'll bet they'll work like you expect.
Old 11-20-2006, 05:44 AM   #5
Technophobe
Wow, that sounds like sound advice, and an avenue i hadn't and wouldn't of thought of, i'll give it a go over the next 24 hours and see if it works.
Thanks for the help m8
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
Adding a timer to my outdoor house lighting ConstantChange Electrical 2 03-31-2007 08:56 AM
Moisture problems when 'heating only when needed' in insulated garage? timg HVAC 10 01-18-2007 05:38 PM
