Digital Clock Advances - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-06-2011, 04:51 PM   #16
licensed electrician
Originally Posted by Mapes View Post
Then it's gotta be ghosts; I live alone, not even a cat.....
that room should be quarantined from all human traffic and sealed
The Deez is offline   Reply With Quote
Old 05-06-2011, 05:53 PM   #17
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I am not adverse to the space-time continuum theory as I've been ... well, kinda new-agey since Mother 'graduated'.
as to being children; attitude is everything in life. If I acted my age I might be accused of being one of the ghosts messing with your clocks.
but, since I don't believe in ghosts, we're down to my theory and some dirty power.
and this has been happening for 15 years? My you have patience.
so, let's get serious.
are you supplied by a public utility company?
have you placed the fast clocks in other rooms and if so, how did they react?
Do you notice any problems or oddities with anything involving electricity?
just to be sure, by digital clocks, you mean the type with LED or LCD display and not the original digital clock that simply had a roll of numbers that spun around like a rolodex (See, I told you I was old. I'm hoping you know what the heck a Rolodex actually is) and there were all of similar type?
have you plugged the clocks into different receptacles in the room? and?
Old 05-06-2011, 06:15 PM   #18
Learning by Doing
Leah Frances's Avatar
Electronics do fail. DH has a digital clock he's had for 20+ years. In the last 5 years it started adding about 3 minutes a month. He refuses to replace it.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-06-2011, 06:20 PM   #19
Rewards Points: 1,192
Buy a wind up clock.
bobelectric is offline   Reply With Quote
Old 05-07-2011, 03:57 PM   #20
Rewards Points: 12
Mother has several wind up clocks.
OK I'll get serious, but you folks will have to wait a month. JUST cleaned out the parent's house today in another sate... and it will be awhile before I'm on the internet back home.
Yes sir, never had it before; I could be older than you.
It is a real live 'modern' clock, and I must say, I've not tried it in another room. Duh, as the kids would say. No other noticable electrical oddities {she says with trepidation...}
Thanks for your patience if you want to wait; I'm curious about power coming in [public; owner wired! not me...]
Mapes is offline   Reply With Quote
Old 05-07-2011, 04:30 PM   #21
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Are these higher end clocks that sync up to a NTP server by chance? Maybe the problem is with the NTP server.
I'm thinking it's related to a time space continuum issue though. Do you live near a power substation? If yes try to find out it's capacity. If it's over 1.21GW look for some crazy looking guy with a Delorean hanging out near there.
Red Squirrel is online now   Reply With Quote
Old 05-08-2011, 12:52 AM   #22
digital clock advances
I once built a digital clock from TTL 74xx chips (this was 30 years ago).
It worked fine, was synchronized to the electric frequency which is very accurate so it worked very well *until* I switched off my old tube radio.
Suddenly the clock had jumped many minutes ahead.
I flipped the switch a few times and the clock was now hours ahead.
Then I understood - the switch was dirty so it caused a series of
contact/no contact transitions. The radio was plugged into the same
circuit that ran the clock, so the series of pulses from the radio's bad
contact caused the clock to see a large number of counts to increment
its time and that is what it did....
I added a filter in the clock and could switch the radio off without the
clock jumping ahead.
You may want to check if there is a particular activity or appliance use
that makes the clock advance.
Just try each switch in the house and check the clock regularly until
you have found the offender.
Then decide if you want to / can plug it into another circuit or try a filter
for your clock.
Success,
Cor.
cvandewater is offline   Reply With Quote
Old 05-08-2011, 11:03 AM   #23
Rewards Points: 12
No NTP servers there. Substation several miles away. I'll be checking to see where the TARDIS landing marks are... Thanks Cor. Gotta get back there and check the other circuits.
Old 05-08-2011, 02:11 PM   #24
Learning by Doing
heee heee he. Maybe there's a time lord on the forum who can help.
Old 05-08-2011, 03:35 PM   #25
nap
You talking to me?
nap's Avatar
hey, I just happened to think about this:
any correlation to the problem and the Large Hadron Collider? After all, they were concerned about creating black holes.
Old 05-08-2011, 10:15 PM   #26
Rewards Points: 12
I am so sorry to report that analytics cannot begin until i get back to home base. I am so looking forward to continuing this thread with verifiable facts. . . . .
Old 05-19-2015, 03:41 PM   #27
Rewards Points: 12
I'm Back!
Update, if anyone is still [interested]
Since I've been back, have tested clock on other circuits with the same result. It drives the fellow who keeps an eye on the place while I'm out of state absolutely mad!
Not having needed the alarm function for several years, and having decided to set said alarm in order to keep an early appt, the deed was done.
Ha! While alarm function is set to on, no advancing whatsoever. At all. Turn that alarm off, and back [or forward as it were] we go!
Old 05-19-2015, 05:21 PM   #28
Rewards Points: 1,402
I like to think of it as just synched to an NTP server on a vehicle slowly moving across time zones...
Space time continuum is less likely because you have to have a reference, and are coming back to the clock's frame of reference to read it. I suppose if you accelerate and decelerate more than it does each day and come back to reference then theoretically less time will have passed for you... but you're talking fractions of fractions of a millisecond when dealing with terrestrial acceleration.
Tom738 is offline   Reply With Quote
Old 05-20-2015, 04:15 PM   #29
Rewards Points: 2,350
I'm Back!
So, uh, what state did you travel to that it took you 4 years to get back? Do you have one of those scam - artist power saver devices on your electrical panel? Purchase one of those Kill-a-Watt power meters and plug your clock into it. It has the ability to show the power line frequency. I'm curious.
Old 05-20-2015, 05:06 PM   #30
concretemasonry's Avatar
Rewards Points: 2,566
Most of my clocks (non-appliance) have a radio connection to a synchronous satellite that they "talk" to hourly to adjust the time. This even includes several battery powered wall clocks ($10 - $25 each) that have the same ability. I just bought 2 plug-in - AM/FM digital alarm clock radios with snooze and choice of alarms notification that have the same ability and a lithium back-up battery. - You just tell the clock your time zone, whether you are in DST or not, set within an hour or so and push the set or go button. You just sit back and it makes a connection and sets/adjusts the clock hourly. Bullet-proof for $20 each.
Dick
concretemasonry is offline   Reply With Quote
