Digital Clock Advances - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2011, 12:18 PM   #1
Rewards Points: 12
digital clock advances
Hi all,
In one room of my house, the digital clock advances up to one hour a day; I assume it's due to [fluctuating?] current from the box? This happens with any clock.
Any ideas?
Mapes is offline   Reply With Quote
Old 05-05-2011, 05:02 PM   #2
licensed electrician
i have no idea, that's messed up though. only thing i can think of is ghosts.
The Deez is offline   Reply With Quote
Old 05-05-2011, 05:31 PM   #3
Rewards Points: 268
I don't recall if AC powered digital clocks use the AC frequency to time themselves (60 hz = 1 second). But they must...Is there anything else on that particular circuit? Cfl's, old fluorescent shop lights (anything with an older ballast), electronics, etc? I know a clock run on modified sine wave (eg from a cheap dc-ac inverter) will make clicks run double-time. Kinda curious on this one...
Marqed97 is offline   Reply With Quote
Old 05-05-2011, 05:32 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,970
What else is on the circuit that it's plugged into?
mpoulton is offline   Reply With Quote
Old 05-05-2011, 06:18 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I imagine most recent clocks use electronics to keep time. As such, it would be based on the frequency (frequency counter in an IC like a 555).
If this happens with multiple clocks, I would suspect that the first one was bad and every one since then has been somebody in your household screwing with you.
Old 05-05-2011, 07:15 PM   #6
Electrical Contractor
kbsparky's Avatar
If the clock has frequency counting circuitry, and you have a bad connection in the power feed, it may count the static of your bad power supply as extra blips in the frequency.
Another possible problem is the clock is configured for 50 Hz power supply, and connected to a 60 Hz source. That would an hour to your display for every five hours of elapsed time.
-KB
Old 05-05-2011, 07:19 PM   #7
" Euro " electrician
frenchelectrican's Avatar
I am thinking the same way as KB is you may have the clock set at 50 HZ supply which it may account the wrong time and few case may have a glitch on the clock when the timming sensor go bad as well.
Merci,
Marc
Old 05-05-2011, 09:21 PM   #8
I bet KB's got it. Most inexpensive digital clocks use the line frequency for timing, very few use an internal oscillator. Somehow you have it set for 50Hz.
Old 05-05-2011, 10:02 PM   #9
nap
You talking to me?
nap's Avatar
but this has been multiple clocks. Unless the OP recently moved to the states from an area that used 50hz and brought a bunch of clocks with him or he got a really good deal on clocks on a late night tv informercial, I would doubt it was the 50hz/60hz issue.
Personally, I think it has to do with the findings of the Gravity Probe B and it's findings with time space and gravity interrelation. The means used to measure gravity and it's effects on space time have somehow created a time warp in the OP's house and speeded up time in that one room.
I would suggest the OP to refrain from staying in the room for any longer than absolutely necessary as while he is in this time warp, he will age faster just as his clocks have and his life, as observed by an outsider, will quicken until his ultimate demise.
The Following User Says Thank You to nap For This Useful Post:
MTN REMODEL LLC (05-19-2015)
Old 05-05-2011, 10:22 PM   #10
Rewards Points: 268
I withdraw my theory. I think nap has something here ;-)
Old 05-05-2011, 10:27 PM   #11
That would be hilarious. A whole shipment of 50Hz clocks, unloaded on TV to unsuspecting Americans at GREAT prices!
Really though, if it's not the clock it's probably a harmonic problem caused by some nonlinear load on the circuit. The clocks detect zero-crossings of the AC waveform. Each zero crossing advances the clock by 1/120th of a second. If some device on the circuit is introducing glitches in the voltage waveform that look like additional zero crossings, the clock will run faster. This is likely to be something electronic, like an electronic ballast or switching power supply.
Old 05-06-2011, 09:18 AM   #12
Rewards Points: 12
I thought, "wow! I'm actually going to get an answer to this 15-year old mystery? Wow!"
But you surely made me laugh! Only thing: used to be hunting cabins; not sure if there Are any ghosts!
Old 05-06-2011, 09:19 AM   #13
Rewards Points: 12
Nothing else on circuit; but I hadn't researched how the clocks 'time' themselves. Interesting tip.
Old 05-06-2011, 09:21 AM   #14
Rewards Points: 12
Then it's gotta be ghosts; I live alone, not even a cat.....
Old 05-06-2011, 09:29 AM   #15
Rewards Points: 12
Children, as a newbie, I find you mahvelous.
I am a young {...} lady; have no TV thus no QVC; never thought to check under the hood of the clock; it's the bedroom in a 3-room cabin so pillow is staying put; I am not adverse to the space-time continuum theory as I've been ... well, kinda new-agey since Mother 'graduated'.
But I'll take any more considerations! Tho I highly suspect the landlord's exaggerated electrical wiring expertise.....
