Old 02-05-2011, 06:23 PM   #1
Digital bionaire calibration
I have a digital bionaire for humidity monitoring. I found it is around 18% lower than the actual relative humidity in my house. Can anyone tell me how can I adjust it by moving the digit forward? I have attached photos on this bionaire, it front and back. Thank you.
Digital bionaire calibration-bionaire-front.jpg   Digital bionaire calibration-bionaire-back.jpg
ccpyue is offline   Reply With Quote
Old 02-05-2011, 10:10 PM   #2
Anything that looks like a screw head that can be turned (potentiometer)? Perhaps on the side of the tan screw block in second picture?
bob22 is offline   Reply With Quote
Old 02-05-2011, 11:31 PM   #3
Look through the whole circuit board, front, back and sides, nothing can be manually adjust.
Old 02-05-2011, 11:45 PM   #4
How did you verify the inaccuracy? Just curious.
Also, Does this unit use a dry and wet bulb which is serviceable?
jlmran is offline   Reply With Quote
Old 02-05-2011, 11:51 PM   #5
http://www.ehow.com/how_6075865_test...ty-levels.html
Learn from above site.
No dry/wet bulb. It use something like a sensor. No manual adjustable can be found.
Old 02-06-2011, 12:00 AM   #6
Experienced
Jackofall1's Avatar
There really is only one tried and true way to verify humidity and that is the comparison of wet and dry bulb temperatures.
A simple sling psychrometer is the best a most reliable instrument to do comparitive calibraition of electronic instrumentation.
It appears that the unit that you are looking at is not capable of calibration.
Mark
Old 02-06-2011, 12:09 AM   #7
Mark
This is only a home use gauge. As long as it close enought to tell me the humidity will be alright. But now, it is 16% lower than the actual one (or +/- actual one), so I wish to adjust my gauge to or close to that.
Old 02-06-2011, 12:12 AM   #8
Experienced
Jackofall1's Avatar
Off from the actual one, what is the actual one and is it accurate? Hence the suggestion for a sling psychrometer.
