Difficult 12A Wire..Tips - Electrical - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 11:41 AM   #1
Difficult 12A wire..Tips
Just wondering if anyone has any tips on how to get 12A wire back into receptacle box without forcing it. I have 2 wires coming and and 2 going out with wire nut ground. 1 gang old work, 18 cubic capacity. Have about 6 inches or so of wire coming out of the box with both incoming and outgoing but cant seem to get everything back in without force and dont want the ground to touch hot or neutral terms.
Any tips would be great. Thanks
suboveryde is offline   Reply With Quote
Old 12-06-2010, 02:05 PM   #2
Mad Scientist
I usually try to bend some folds into the wires first, so that when you push the device into the box, they'll tend to fold in neatly. You should be able to bend the ground such that it folds in away from any of the other terminals.
I usually try to get it so that the wires coming in to the top of box go straight down to the bottom, fold up to the top, then down again, before bending straight out to the device screws. And the opposite for wires coming in the bottom of the box. If you can visualize that, it's easier to do than to describe.
It's still a pain sometimes, but you'll get it if you try it a couple times.
McSteve is offline   Reply With Quote
Old 12-06-2010, 06:34 PM   #3
Graduate of Wiring 1-2-3
Let's see if the box is big enough for those wires:
2 blacks
2 whites
2 grounds
1 more ground for the box
1 for the receptacle
8 X 2.25 for 12 gauge wire
=18 cu. in. total OK! that should fit in that box.
I think you are talking about 12 gauge wire, not 12 A wire, because that stuff is hard to bend into a small area. McSteve's got some good advice. I try to fold the wires into the back of the box where there is more room before pressing on the receptacle.
Lurlene is offline   Reply With Quote
Old 12-06-2010, 06:45 PM   #4
Rewards Points: 1,192
Turn off circuit,tape receptacle screw terminals, fold conductors out of the way,watch to see the ground wire is ok.
bobelectric is offline   Reply With Quote
Old 12-06-2010, 07:17 PM   #5
2 blacks
2 whites
2 grounds
All grounds only count as (1)
Device (outlet) counts as (2)
Old 12-06-2010, 07:35 PM   #6
Mad Scientist
... I think you are talking about 12 gauge wire, not 12 A wire, because that stuff is hard to bend into a small area. ...
I didn't even notice this. I assumed he meant 12GA, since I'm so used to seeing "12 gauge" and "Difficult" in the same sentence.
Old 12-06-2010, 08:58 PM   #7
Thanks for the replies I appreciate it. Yes i meant 12 gauge wire (12/2) sorry 12G and 20A has been running circles in my mind for the past 3 days. Thanks again for the tips.
Hey if anyone has time one more quick question, that last outlet in the series only has 1 black, 1 white and 1 ground + receptacle going into it, the problem is that since I have to use Old Work boxes, I am hitting a 2X4 that is in the wall as diagonal bracing and can't get it flush. Has anyone had experience with a shallow box (8 cubic)?
Old 12-06-2010, 11:31 PM   #8
Thanks for the correction, Scuba Dave. I was using the Home Depot calculation method...probably not the most accurate.
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
wire running question ponch37300 Electrical 4 04-21-2009 03:58 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
New Dryer is 3 wire, receptacle is 4 Wire. thelimit Electrical 22 01-15-2009 09:59 AM
