Difffernt Voltages In A Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2013, 09:53 AM   #1
difffernt voltages in a panel
is it code to have several different voltages -600, 120 vac and 48vdc, in the same panel ?
conrad cromwell is offline   Reply With Quote
Old 04-02-2013, 09:58 AM   #2
Rewards Points: 12,818
Please go back and add your location to your profile!
Just go to Quick links to edit.
Old 04-02-2013, 11:28 AM   #3
Depends where and what you mean by panel.
64pvolvo1800 is offline   Reply With Quote
Old 04-02-2013, 12:17 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,858
If you are talking about a panelboard with overcurrent protective devices, then it's is very unlikely that would be code compliant. Theoretically possible, but it would be a very special custom installation and there's probably no good reason for it. In other contexts like control panels, it is very common to have multiple voltages and classes of circuit in one device. Certain rules regarding wiring methods and separation apply.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
Old 04-02-2013, 08:02 PM   #5
Idiot Emeritus
Rewards Points: 1,492
I've built industrial control panels that were fed with 480 3, had 480 motor starters and VFDs in them, plus a control transformer for 120, plus a 24DC power supply.
Most motor control center buckets have both 480 and 120, VFD ones have 480, 120, and 24DC.
I've also seen split-bus switchgear that had 480 on the top busses and 120 on the bottom set.
It's also common for a ball field lighting switchgear to have a 480 panel and a 120 panel mounted in the same section with no separation between them. But they are two (or more) separate panels.
Rob
micromind is offline   Reply With Quote
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 04:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
