Differing Circuits/amperage Share Same Gang Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2012, 01:47 PM   #1
m2234's Avatar
Differing circuits/amperage share same gang box?
Hi all - I live in Massachusetts, and wiring a new addition to my house. Does anyone know if it's code-compliant to install a 30 amp receptacle from 1 circuit, & a 15 amp receptacle from a different circuit in the same 2-gang box?
I know I could install each in their own box, but prefer the simpler appearance of a 2-gang.
Thank you!
m2234 is offline   Reply With Quote
Old 03-21-2012, 01:51 PM   #2
liscenced electrician
Rewards Points: 538
Not a problem as long a box fill isnt exceeded. It's the voltage that is the deciding factor, not amperage. When this is an issue is when you try to run low voltage cable with line voltage. Most low voltage cable isn't rated for 120v, so it must be seperated
jimmy21 is offline   Reply With Quote
Old 03-21-2012, 02:05 PM   #3
m2234's Avatar
Great-thx! My plan is for one receptacle to be fed via 10/2 wire, the other with 14/2. Both at 120V. How can I determine if this will exceed box fill?
Old 03-21-2012, 03:29 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
What is the useage for the 30 amp 120 volt receptacle?
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
jimmy21 (03-21-2012)
Old 03-21-2012, 03:43 PM   #5
Licensed electrician
Rewards Points: 1,296
You may not be able to find a cover plate for this.
Like RJ, I would like to know what the 120 volt 30 amp receptacle is for.
Old 03-21-2012, 07:32 PM   #6
m2234's Avatar
The 30 amp is for 1 of two separately-located receptacles that are dedicated to two large window AC units. Great point about the cover plate - never thought about that! I'll have to scour the Internet for one...
Thanks everyone, for your wisdom :-)
Old 03-21-2012, 07:59 PM   #7
Rewards Points: 82
And it is highly unlikely the two receptacles will fit in the same enclosure. If they will fit at all. Take a look at a standard 30 amp dryer receptacle. It has to be by itself, all alone in the box.
This is done for a reason. To keep people from doing what you propose.
Separate circuit, separate box and plates for each circuit in YOUR instance.
Old 03-22-2012, 02:41 PM   #8
I would put them in separate boxes too. I just installed a 30 amp RV plug in my barn. I had to put it in a two-gang box by itself because it was just just slightly too big for the 1-gang box I had. I installed in an outdoor box with outdoor cover, so I may have had a little less room, but I don't know if both the 30-amp and 15-amp outlets will fit.
And as was said, you'll have a hard time finding a cover for the box. I did a quick search at the Leviton site. The closest I found was this one, but your 30-amp outlet will not fit the hole:
brgmgb is offline   Reply With Quote
Old 03-23-2012, 08:47 AM   #9
m2234's Avatar
Really appreciate everyone's advice. I recalculated the 2 AC window unit amperage, and have determined that an 8k BTU unit and a 10k BTU Unit will fit on a dedicated 20 amp circuit. No more 30 amp to try to jam into boxes. Thank again, all!
Old 03-23-2012, 11:54 AM   #10
Rewards Points: 82
You don't figure if they will fit as you say. Each unit has its requirements listed right on the nameplate. This is how you size the circuit. To the manufacturers specs.
Do not add up the current (amps) and size the circuit this way. Better to do it right the first time.
Besides. How did we get from 30 amp to 20 amp requirement. Makes no sense. Its either 20 or 30. What does it say on the nameplate for each unit?
Old 03-23-2012, 12:46 PM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
An 8k and/or 10k A/C would NOT be allowed on a 30A circuit anyway since they would both have 15A plugs on them.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
J. V. (03-23-2012)
Old 03-25-2012, 10:46 AM   #12
m2234's Avatar
I haven't purchased the AC units yet. But manufacturer specs indicate both pull a combined 15.5 amps, which is less than 80% of a 20 amp circuit. They are both 110/120 V plugs. Did I calculate correctly?
Old 03-25-2012, 10:49 AM   #13
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Sorry, misread the post. I don't see a problem putting both AC's on the same 20A circuit. I don't remember them drawing only 7.5 A, but I guess I don't doubt it.
Old 03-25-2012, 10:53 AM   #14
m2234's Avatar
How could both pull 30 amps when running at same time? One pulls 8.3 amps, the other pulls 7.2 amps. That's how I arrived at 15.5 amps total - with both running at the same time. Thx.
Old 03-25-2012, 11:05 AM   #15
A "Handy Husband"
rjniles's Avatar
The starting amps may be a problem, I would use separate circuits.
Cutting/capping old cables - What to do with grounds & put these in oversize gang box darlingm Electrical 3 12-22-2011 12:40 PM
Dual Bath Vanity GFCI - Single Gang Boxes or a Single Two Gang Box? WoodmanFL Electrical 2 12-11-2011 08:39 PM
Gang box falls through drywall hole because its too big. Jakobud Drywall & Plaster 7 04-12-2011 09:20 PM
wiring a single gang and 3 gang box from one source twinkietrucker Electrical 4 02-17-2010 08:01 AM
2 gang old box, made into 3 gang, off center?? fabian Electrical 9 01-15-2010 10:46 AM
