Different Ways To Wire A Outlet Controlled By Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 11:01 AM   #1
Rewards Points: 150
different ways to wire a outlet controlled by switch?
curious on how a outlet (both plugs, not one) can be controlled by a switch. any diagrams or pics? thanks
fabian is offline   Reply With Quote
Old 01-13-2010, 12:08 PM   #2
Licensed electrician
Rewards Points: 1,608
One a half switched receptacle the brass tab is broken off. There would also be a constant hot on one of the screws. Depending on the wiring scheme there would be a couple of options for the switched duplex.
Old 01-13-2010, 12:18 PM   #3
Rewards Points: 150
If you break off the tab wouldn't just one half be powered? I'm asking about both being powered on/off by the switch
Old 01-13-2010, 12:21 PM   #4
Inspector/Instructor
codeone's Avatar
Yes that is correct. Usually what people do is run a 3 wire from the switch to the rec install the black wire to one of the brass screws and the red to the other break the tab and have one rec hot all the time and the other switched. White wire going to the silver screw and not breaking the tabon that side.
codeone is offline   Reply With Quote
Old 01-13-2010, 12:29 PM   #5
300zx's Avatar
Post
300zx is offline   Reply With Quote
Old 01-13-2010, 12:31 PM   #6
Question
You could have both (individual ) receptacles switched, by installing a duplex (a/o opposed to 2-gang) switch and running ALL three wires to the DUPLEX receptacle. But you might have an issue with "Box Fill", if installed in certain ways, like on a 2-gang box or with a 2-gang cover! (No matter what) Don't Drink and Drive, Ever!!!!
spark plug is offline   Reply With Quote
Old 01-13-2010, 12:32 PM   #7
300zx's Avatar
Old 01-13-2010, 12:34 PM   #8
joed's Avatar
Rewards Points: 12,852
There are several different ways to wire this. Power could go to the switch first, the receptacle first. There could unswitched power going to other receptacles.
Any drawing you see for a light fixture can be used by substituting a receptacle in place of the light.
Old 01-13-2010, 01:48 PM   #9
Rewards Points: 150
Originally Posted by 300zx View Post
so if i pull the switch out. and see only 14/2 wire. then its got to be hooked up like above right? because both top and bottom plugs on the outlet get worked by the switch.
Old 01-13-2010, 02:09 PM   #10
300zx's Avatar
Post
Yes, If you have 14/3 wire then the other diagram will work and you have to break the tab on the hots.
Old 12-13-2012, 09:16 PM   #11
Rewards Points: 117
sorry to bump an old post but this is what im looking for. however if i wanted to control 2 outlets how would i wire in the 2nd outlet?
echobravo is offline   Reply With Quote
Old 12-13-2012, 09:23 PM   #12
You could pigtail off the switch or wire from the second set of screws on the receptacle. Depends on the physical arrangement and locations.
help with wiring ceiling fan from a switch controlled outlet teamster807 Electrical 39 10-27-2011 04:09 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
HELP I need to wire a switch to an outlet to hook up my garbage disposal r8drman69 Electrical 8 06-05-2007 10:18 PM
