Different Size Wires In A Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2008, 05:21 PM   #1
Different size wires in a circuit
I think I know the answer to this one already, but I seem to remember someone telling me years ago that it is acceptable to feed a smaller gauge conductor from a larger conductor: i.e. #12 feeding a #14, or #8 feeding a #10.
This can't be correct since, for instance a #12 is rated at 20 amps and a #14 is only rated at 15 amps.
However, since it's an accepted practice to use 15 amp receptacles with #12 wire, would it not be acceptable to feed a 15 amp outlet with #14 with that conductor originating in a junction box fed by a #12?
Logic tells me that it's not. But if you don't ask....
Randell Tarin is offline   Reply With Quote
Old 04-12-2008, 05:33 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
Why do you need to mix wire sizes in the first place.
Just keep all wires the same size on a circuit.
Old 04-12-2008, 05:34 PM   #3
Yes......As long as the circuit was protected by a 15 amp breaker.
The breaker protects the wire so it must (generally) be sized according to the smallest conductor.
220/221 is offline   Reply With Quote
Old 04-12-2008, 05:38 PM   #4
Obviously keep them the same size. But, you know as well as I that there are a lot of cheap people in these forums. And there are those who would take shortcuts. The number of DIY horror stories described here will atest to that.
As a hypothetical, could Joe Blow safely run a #14 to a 15 amp plug with the circuit being fed by a junction box from a #12 conductor on a 20 amp breaker?
Old 04-12-2008, 05:56 PM   #5
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
No. That would be neither safe, nor code compliant. The 14 must be protected by no higher than a 15 amp breaker or fuse. Consider, we are talking about duplex receptacles. 2 toasters or 2 hair dryers could be plugged in to that one 15 amp receptacle you mentioned, overloading the 14 gage wire.
Here is something else I have seen. Someone runs #12 wire from the panel to a J-box. Then runs in a couple directions with #14 for receptacle outlets. He properly lands the #12 on a 15 amp breaker. Along comes the next guy, who sees the #12 in the panel and moves it to a 20 amp breaker, not knowing there is #14 in the circuit.
It is best to use the same size wire on the entire circuit unless dealing with a voltage drop on a long run.
Last edited by jrclen; 04-14-2008 at 01:14 PM. Reason: fingers go faster than brain sometimes
jrclen is offline   Reply With Quote
Old 04-12-2008, 06:09 PM   #6
As long as the breaker is sized to the smallest wire on/in the circuit it is safe.
Is it a hack job, yes, but it is safe.
Old 04-12-2008, 06:24 PM   #7
Electrician
On a DIY forum I agree, in the real world with real electricians, what are you thinking?
chris75 is offline   Reply With Quote
Old 04-12-2008, 07:18 PM   #8
In the real world you sometimes have to make do with what's on hand until you can do it correctly.
There are numerous trades that utilize electricity. When it's a matter of being "McGyver" and jerry-rigging or not getting the job done, people will do whatever's necessary; sometimes to their own detriment.
It's helpful to know what's doable and what's not.
Old 04-12-2008, 07:40 PM   #9
Sure buddy. I live and work in the "real world". It NEVER gets done correctly afterwards. It remains a hack job until either someone replaces the whole mess during a renovation or re-build, or someone gets hurt.
Someone can try to justify their actions all they want. A hack job is still a hack job.
Old 04-12-2008, 07:57 PM   #10
electrician
[quote=Speedy Petey;115811]Sure buddy. I live and work in the "real world". It NEVER gets done correctly afterwards. It remains a hack job until either someone replaces the whole mess during a renovation or re-build, or someone gets hurt. [quote]
Yeah, I've been there. Didn't have enough stuff to finish the job and had friends who I was "doing a favor for" say they would finish it for me. I trusted them and later got dinged by the inspector for what they didn't finish. It never happened again!
Silk is offline   Reply With Quote
Old 04-12-2008, 08:23 PM   #11
Originally Posted by Joba Fett View Post
Please don't encourage these frugal DIYer's. It almost seems YOU are looking for a positive response to this type of post, or otherwise why would anyone that has any common s***e post this type of @@@@.
Posts like this are really not necessary.
Please try to do more meaningful things with your time.
No one is encouraging anyone. Just trying to get a good discussion going on a subject that we've all seen done over and over. And besides, I are a frugal DIYer.
I'd rather everyone do it the correct way, but that doesn't always happen does it?
Old 04-12-2008, 09:20 PM   #12
No, unfortunately it doesn't. That is why most of us come here to help. We are trying to encourage doing things the right way.
I have to say though, your posts do look like you are looking for justification for NOT doing it the correct way the first time.
Old 04-12-2008, 11:10 PM   #13
Geez, you guys were chiding me in another thread for using only #12 wire for everything. I would never, ever do this.
You're wrong. I'm not looking for anyone to condone anything. I had seen this done in practice and had been told it could be done and was just curious to know what the pros thought. I thought other DIYers would benefit from knowing the dangers.
You can think what you want. My intentions were good.
Old 04-13-2008, 12:01 AM   #14
electrical contractor
Rewards Points: 150
what about the ten foot tap rule?
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 04-13-2008, 12:20 AM   #15
When is fishing season?
CowboyAndy's Avatar
I have heard alot of people trying to justify doing this with lighting... where you have a 20AMP 12AWG circuit to a bunch of receps, then to a switch. Then they proceed with 14AWG to the lighting.
Again, it's not about what's convient or whatever. Its about code.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
Circuit breakers and wire size stan 41943 Electrical 19 03-06-2008 03:29 PM
Transformer Help chcustom Electrical 28 12-10-2007 11:40 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Number of receptacles and size of wires KUIPORNG Electrical 5 06-28-2006 02:21 PM
