Old 03-25-2011, 11:19 AM   #1
Different Load Baseboard Heaters in Parallel
I'm planning what baseboard heaters to buy for my 150 sq ft enclosed porch and have calculated the Wattage at 1500 Watts. Because of furniture layout, I'd prefer to install one 1000W and one 500W and have them controlled by a wall mounted 'double pole' thermostat wired in parallel (as in attached diagram).
Assuming 240V with a Honeywell TL7235 or similar thermostat.
Question: Is it safe to wire up two baseboard heaters with different wattage like this? Would the 500W heater get overloaded? Should I use two 750W heaters?
pankaek is offline   Reply With Quote
Old 03-25-2011, 12:27 PM   #2
Electrical Contractor
You are good to go like that.
The heaters will not overheat.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
pankaek (03-25-2011)
Old 03-25-2011, 01:11 PM   #3
Any recommended Brands?
Was looking at the Cadet Softheat models.
Old 03-25-2011, 01:50 PM   #4
I have never installed baseboard heat, so I can't help on the brands.
Old 03-25-2011, 03:52 PM   #5
I=E/R
a7ecorsair's Avatar
My new house has many Cadet baseboard heaters. There are five 20 amp circuits supplying them with power. Some are on wall thermostats, some with baseboard mounted thermostats and some with definite purpose 24v control relays. I have mixed wattage on the circuits.
Your diagram is fine and you can join the wires in the end of one unit. One unit will provide more heat but it won't be overloaded. They will both get 240 volts and circuit current will be the combination of the two heaters.
a7ecorsair is offline   Reply With Quote
Remove a big baseboard and add 2 smaller ones Metallo HVAC 6 01-29-2011 08:07 PM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 10:30 AM
Baseboard Heat 80% Rule Question bltglt507 Electrical 1 11-06-2009 12:17 PM
Baseboard heaters ignoring thermostat marcus_1111 Electrical 9 08-06-2009 12:00 PM
Electric Radiant Baseboard and Built-in Bookshelves arobin HVAC 4 07-08-2009 06:42 PM
