Different 3 Prong Dryer Cords - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 09:16 PM   #1
Different 3 prong dryer cords
I just purchased a used clothes dryer. I knew about the 3 and 4 prong plugs so I made sure I got a dryer with a 3 prong plug to match my old dryer/outlet. But... I found out the configuration of my new dryer 3 prong cord (2 straight, 1 L shaped) does not match the old dryer/outlet (3 straight prongs). What is the difference, and what can I do - don't want to spend a lot of money. Thanks for your help.
smstorm is offline   Reply With Quote
Old 04-17-2011, 12:49 AM   #2
" Euro " electrician
frenchelectrican's Avatar
I will post couple diffrent verison what you are talking about for the dryer plug and receptale and some case it may be a range receptale as well so let me post it.
here one .,
Here other one .,
Here other one this is a triwire 50 amp range repectale.
Here other type of 50 amp this is typically used for welder or very large single phase compressour
Let us know which one you have if none show up then myself or other members in here will pull up the larger chart it will cover all the stragiht receptales for North Americian side.
Merci.
Marc
Old 04-17-2011, 12:50 AM   #3
Electrical Contractor
kbsparky's Avatar
Sounds like you have a range outlet there:
This is what a dryer outlet should look like:
-KB
Old 04-17-2011, 02:58 PM   #4
Sparky
Rewards Points: 510
i would just take the cord off of the old dryer and put it on the new dryer.
be sure to unplug it before you do this, of course.
Techy is offline   Reply With Quote
Tags
3-prong dryer cord
3 prong dryer to 4 prong issue titan Electrical 9 07-27-2011 08:23 AM
3 prong to 4 prong dryer cord nwilson1987 Electrical 6 09-08-2010 12:11 AM
Installing a 4 prong dryer plug Amandamayes Appliances 4 07-16-2010 01:17 PM
converting a 4 prong dryer outlet into a 3 prong dntbro1994 Electrical 8 07-02-2010 10:25 PM
Please help, changing dryer cord from 3 prong to 4 prong oldpirate Electrical 8 08-10-2008 04:42 PM
