Differences Between These Light Switches? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 05:02 AM   #1
Arrow
Differences between these light switches?
I could only find these two examples online, but in store at HD there are different grades up to the type labeled commercial.
  1. R52-01451-02W
  2. R62-RS115-02W
What exactly are the differences between these two and other more expensive 15 amp single pole switches?
argh is offline   Reply With Quote
Old 10-27-2010, 05:48 AM   #2
One difference that jumped out at me was the label "quiet". I assume that the more expensive one has a little smoother and quieter toggle action.
oberkc is offline   Reply With Quote
Old 10-27-2010, 08:47 AM   #3
Rewards Points: 512
Old 10-27-2010, 07:39 PM   #4
Yep, I noticed it was labeled quiet - what makes it more quiet and what else could possibly be improved over the cheaper versions as we go higher in pricing?
Old 10-28-2010, 07:37 AM   #5
I=E/R
a7ecorsair's Avatar
Why are some car tires rated for 40,000 mile and some for 80,000 miles? They are all round and hold air
How about country of origin.....
a7ecorsair is offline   Reply With Quote
Old 11-01-2010, 10:22 PM   #6
Ravenworks's Avatar
Could it be the Brass grounding lug on the bottom screw plate?
Ravenworks is offline   Reply With Quote
Old 11-02-2010, 06:10 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
One is a heavy-duty and the other is a cheap resi-grade device. A true spec-grade device would be even better (more heavy duty) and more expensive.
Your answer is right in the descriptions:
R52-
For standard household use
R62
Ideal for use in heavily used areas in homes, offices, schools and commercial buildings
Old 11-02-2010, 06:23 AM   #8
Electrical Contractor
kbsparky's Avatar
Here is a better one, Leviton 54501-2W for a buck, twenty-five:
-KB
Old 11-02-2010, 08:45 AM   #9
Ravenworks's Avatar
That is not the switch in the second link ,I just bought some of the R62-RS115-02W switches and they have a Brass lug with two wires that hold the screw in place.
However,for curiosity sake I went down to my goodie box and it seems that Leviton may have done a revision to this particular model as I have both types of this model switch,with and w/o brass lug.
Old 11-02-2010, 02:52 PM   #10
He didn't say it was. He said:
Here is a better one...
Old 11-02-2010, 06:33 PM   #11
kbsparky's Avatar
-KB
Old 11-02-2010, 09:12 PM   #12
If my math is right, the difference is 49 cents.
Just kidding.
The R62 is considered a little more heavy duty, as Speedy Petey said. I just installed 6 of the R62s and have installed several of the R52s in the past.
The R62 has a more "positive" feel to it when switched, if that makes sense. It is also a little louder.
But what I found really convenient is that the R62 is provisioned for "back wiring" as opposed to "back stabbing". I know that might open a can of worms here, but it seems really secure to tighten down the screw on the clip without having to loop the wire around the screw. Similar to tightening down a wire on a breaker.
itin1200 is offline   Reply With Quote
Patching plaster around light switches 2muttsmom Drywall & Plaster 13 08-20-2010 02:33 PM
3 way switches with light load on both ends boutwater Electrical 2 03-07-2010 12:05 PM
Two Ceiling Light Fixture switches suddenly acting flakey!!! babalina Electrical 5 10-12-2009 07:52 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
adding an additional light to 2 3-way switches basement_guy Electrical 10 07-20-2008 09:23 AM
