Differences In 2xx Voltage Appliances? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2009, 01:10 PM   #1
Question
Differences in 2xx voltage appliances?
I have purchased an appliance that says it uses 236 volts. Can anyone tell me what I should be getting in my house, and what difference it makes if the appliances say "230, 236, 240, or 250 volts"?
I keep seeing different voltages for different devices, but I think I am limited to whatever I get from my electrical panel.
Roy Rowlett is offline   Reply With Quote
Old 09-17-2009, 01:29 PM   #2
Licensed Pro
Typical residence in the US has 120/240V service. Some multi-unit condos may have 120/208 service.
Old 09-17-2009, 02:09 PM   #3
joed's Avatar
Rewards Points: 12,002
I would consider all the voltages you listed as the same and use any appliance with them listed on my home 240 volt system. 208 is a different anaimal. It is part of a three phase system
Old 09-17-2009, 02:54 PM   #4
208v not for home use?
Are you saying that if I buy a device that uses 208v, it must be on a 3 phase system, and therefore would not work in a typical 2 phase home environment?
Old 09-17-2009, 03:16 PM   #5
Code05's Avatar
Rewards Points: 1,104
1. your house is single phase, not double phase.
2. unless you are interested or need to know about 208v and three phase, just forget about it and do not buy anything marked 208v as the only usable supply voltage. Some things are marked 208/230, these are okay.
Code05 is offline   Reply With Quote
Old 09-17-2009, 03:22 PM   #6
Household Handyman
Rewards Points: 1,408
Mr. Rowlett, may I ask where you live that you buy an appliance which is rated for 236 volts? For myself, that is very unusual voltage for an appliance. "Code05" gave you a very good answer on this also. Thanks, David
Old 09-17-2009, 03:49 PM   #7
Code05's Avatar
236v was probably just a labeling mistake at the factory. I have seen similar wierd voltages a few times
Old 09-17-2009, 03:50 PM   #8
I live in western NC and north central FL.
I am looking at an item on eBay. It is a commercial electric hot plate. I want to use it for canning in my basement in NC. It would take up less room than a standard electric stove with heating coils, and would require the same power. I am assuming if I can use it, it will need a 230v/30 amp circuit like a stove.
My kitchen stove has a glass top, and the canner is too wide for the eye on the stove top, so could break the glass. That is why I am looking at this option. Also, since this would be seasonal, I could put it away during the off season. I could not do that with a second stove.
The description on eBay says it can be set up for either 3 or 1 phase. 208 vs 236v. I don't know why it says 236v vs 230v.
Here is the link:
http://cgi.ebay.com/ws/eBayISAPI.dll...E:B:EF:US:1123
Old 09-17-2009, 04:00 PM   #9
1 phase vs 3 phase?
Thanks for setting me straight on that. I am not an electrician, and I don't really understand the meaning of that. I know I can probably look this up, but just as an aside:
Isn't it true that the way we get 230v in my house is combining 2 phases of 115v, so that the effective voltage is 230v? I know I get 2 hot leads from the power company at 115 v each, out of phase with each other, and if I use one side, I get 115v. If I use both sides, I get 230v. If the alternating currents of the 2 hot leads are out of phase with each other, the resulting "combining" of those 2 lines yields an effective difference of potential of 230v? Am I missing something?
Or is this just a nomenclature issue? Like the 3 way switch thing - when there are really only 2 switches that control a light, yet it is still called a "3-way". Would it follow that if I have one switch controlling a light, it would be a "2-way"? That makes no sense to me either.
Old 09-17-2009, 05:01 PM   #10
Code05's Avatar
Here is the link:
The cord is 240v 30 amp, which is the old 3 wire plug configuration on a dryer. It will work at your house. 220/230/240 are all the same. 208 is a three phase voltage catagory, but if you usu only two of the "hots" it is single phase. Heating elements work fine on 208 or 240.
Old 09-17-2009, 05:14 PM   #11
Code05's Avatar
Your house is Center tapped single phase service or Split phase. I do not type well and it is too long for me to explain, look it up if you want to. Now go buy the range and call me when the pizza is ready.
Old 09-17-2009, 10:38 PM   #12
Rewards Points: 1,446
The standards for (non-3-phase) household current is 110 to 120 volts and 220-240 volts. I mean, the "236 volt" appliance will work just fine on anywhere from 220 volts to 240 volts.
To a 220-240 volt appliance (often labeled with just one number between 220 and 240), 208 volts is a brown out condition unless the appliance is also rated for 208 volts. There are a few other idiosyncrasies specifically related to 208 volts and those "220-240 volt" appliances that require that you connect the neutral as well to power portions of the appliance that want 110-120 volts. So don't connect up 208 volts unless the appliance is rated for that.
The 240 volt appliances that also use 120 volts (require the neutral) may be labeled 120/240 or 110/220.
AllanJ is online now   Reply With Quote
Old 09-17-2009, 11:17 PM   #13
Thumbs up
Clarifying Terminology.
Code 05 (Poster #10 & 11) You gave an excellent reply to Roy Rowlette (#9) He seems to be perplexed with the terminology of Single Phase and (2-phase Non-existent) 3-Phase. Let me try to put in my Two Cents. The difference between Single Phase and Three Phase has no practical bearing for the consumer. Two "legs" of a system will always be considered to be Single Phase. The difference is in the Voltage. In a single phase system, the voltage will be 120/240. In a Three phase system, it is. 120/208V. Whether you use Two or Three wires. In order not to get too technical (which this forum is not meant for) the explanation will not be given. No matter what.Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 09-17-2009, 11:22 PM   #14
220/221.......whatever it takes
220/221 is offline   Reply With Quote
Old 09-17-2009, 11:35 PM   #15
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
typical residential electrical supply is 120/240. They left the old 110/220 or 115/230 quite a long time ago. There are federal standards that have made the current supply voltage to be the 120/240 +/- 5%.
what an appliance is rated can vary depending on what the manufacturer intended. If an appliance is rated 220 volts, it can be used on a 208 system acceptably as NEMA (national electrical manufacturers association) requires that appliances be able to utilize voltages that are +/- 10% of name plate rating.
a 220 volt rated appliance could be run on voltages that run from 198 to 242.
The appliance you are looking at would be able to be powered on anything from 212.4 to 259.6 volts.
Not sure why they chose that voltage as it does not allow it to be run on any other standard voltage in the US. I would think it is a foreign built appliance. They often list odd voltage on their machines and appliances.
spark plug writes:
never seen a 120/240 volt 3 phase system? aka high leg delta?
allanj writes:
. If the neutral is required, both the line to neutral and the line to line voltages will be listed. e.g. 120/240 or 120/208
spark plug writes:
actually, not non-existent. Very uncommon and very ancient and not typically seen but definately not non-existant.
How to convert electrical voltage of appliances a.kkkoh Electrical 7 08-23-2009 11:55 PM
Are European appliances really that much better? home_improver Appliances 2 09-30-2008 07:06 PM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 10:01 PM
