Difference In Square And Round Flood Lights? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 12:16 AM   #1
Rewards Points: 308
Difference in square and round flood lights?
What is the main difference between floodlight holders with just the bulbs exposed and the square ones with the horizontal bulbs?
smokey847 is offline   Reply With Quote
Old 02-05-2012, 12:20 AM   #2
Julius793's Avatar
Depending what kind of box is in back of the fixture.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-05-2012, 12:23 AM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
The units with the square heads are normally halogen bulbs
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-05-2012, 09:07 AM   #4
The square fixtures most often will have a double ended quartz halogen light bulb. Usually they will come with anything from a 150-500w bulb, but I've seem some as high as a 5,000w as well, just in case you have a beach to light from 40ft. up.
The basic lampholders are just that. Pretty basic. They take a standard PAR38 halogen and are generally rated up to 150w per socket. The Taymac brand ones I'm familiar with seem to hold up reasonably well.
LooseSCruz is offline   Reply With Quote
Old 02-05-2012, 09:30 AM   #5
Licensed electrician
Rewards Points: 1,622
The pattern of light distribution will also be different.
LooseSCruz (02-05-2012)
Transition From Square To Round rjordan393 HVAC 2 07-29-2011 09:48 AM
Square recessed lights in breezeway chronojosh Electrical 2 03-15-2011 10:21 PM
Duct square to round to square flow question unixb0y HVAC 2 08-26-2009 05:12 PM
Poor Attic Ventilation Mechanically Challenged Roofing/Siding 15 10-23-2008 09:05 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
