Old 05-08-2012, 04:29 AM   #1
Difference between these two push-in wire nuts?
Maybe I'm just dumb, but I can't quite figure these 2 out. I'm wiring up a 6 zone Lutron Grafik Eye QS and I need to have 7 12ga wires connect for the neutral and the ground. These seem like the best way to go, just because the number of wires as well as the limited room in the box.
This one says for "grounding terminations only"
This one says for "non-grounding terminations only"
I'm not following why there'd be a difference. Why can one only be used for grounding only, and one for non ground connections?
Maybe I'm just reading it all wrong.
jailbird371 is offline   Reply With Quote
Old 05-08-2012, 05:13 AM   #2
Ravenworks's Avatar
Because one is green signifying ground.
Ravenworks is offline   Reply With Quote
Old 05-08-2012, 07:12 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Thing is there is nothing in the code to justify this.
I think it is a marketing thing.
Old 05-08-2012, 07:20 AM   #4
Licensed Electrician
k_buz's Avatar
I find the "Essential Information" counter productive to sales....
Essential Info
Wire nuts come in handy for J-box installations, but wires can pull out accidentally, leaving you without a secure connection. Guarantee perfect eight-wire grounding installations every time with this 50-pack of 8-Conductor Ground Wall Nuts. Safe for use with 18- to 12-gauge solid wire or 16- to 12-gauge stranded wire, these wire connectors will hold wires securely so they can't pull out accidentally. A transparent housing provides easy inspection.
Old 05-08-2012, 08:14 AM   #5
Licensed electrician
Neither Wago or Ideal make any mention of needing a different connector for grounding vs non-grounding. Could have been written by someone that thought the green could only be used for grounding.
Code05 (05-08-2012)
Old 05-08-2012, 09:04 AM   #6
I=E/R
a7ecorsair's Avatar
That is poorly worded. The first sentence is about wire nuts and saying that wires can pull out of the nut.
Now if you pre-twist------------------------------------------
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
k_buz (05-08-2012)
Old 05-08-2012, 09:11 AM   #7
k_buz's Avatar
Completely missed that....
BTW...I consider wirenuts a better product to the push-in connectors. Reminds me way too much of a backstabbed device. Also, I thought I remember reading that the push in connectors are a one-time use item. If you have to take any wires out of the connector, you have to replace it.
Sorry, I know I just opened "Pandora's Box"........
Old 05-08-2012, 11:50 AM   #8
Are you sure that the green one for grounding terminations does not have exposed metal? This would be unacceptable for use with ungrounded conductors.
Two or more wires, even pretwisted, won't work in one hole of one of these push in connectors even if the hole was big enough. The spring clamp inside will not hold multiple conductors, even pretwisted, in good contact.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 05-08-2012, 11:53 AM   #9
From looking at Wago's website only the color of the insert looks different.
Old 05-08-2012, 12:53 PM   #10
Just a DIY guy
The Ideal ones say you can reuse them. The wires pull out pretty easily if you twist them in the connector, but you are supposed to restrip any wires you remove that way. I have used them in some crowded (not overcrowded) boxes, but I do think regular wire nuts are more secure.
M3 Pete is offline   Reply With Quote
Old 05-08-2012, 04:22 PM   #11
Ravenworks's Avatar
I agree with you guys in the marketing,I do not agree with the manufacture saying they can be used on stranded wire,it's disappointing to say the least.
I would venture to say they would be good for lite loads but would feel better about wire nuts for high load circuits,correct?
Old 05-08-2012, 04:59 PM   #12
They are rated for the circuit size so I don't see the concern about only on light loads.
Old 05-08-2012, 08:25 PM   #13
Ravenworks's Avatar
Fair enough
Old 05-08-2012, 10:55 PM   #14
Master Electrician
a couple of "big blue" wire nuts should fit in the box no problem with the graphic eye. unless you want to buy youself a soldiering iron and some heat shrink there's not many connections that are going to top a pretwist wire nut connection.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Ceiling fan and wire gauge needs? greentrees Electrical 6 05-01-2012 02:05 AM
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 02:23 PM
Wire nuts w/ holes in top JakAHearts Electrical 25 06-08-2010 11:50 AM
Wire Nuts jamiedolan Electrical 36 09-16-2009 12:41 PM
