Difference Between Distribution Transformer And Furnace Transformer - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 03:47 PM   #1
difference between Distribution Transformer and Furnace Transformer
What is the difference between Distribution Transformer and Furnace Transformer?
e3belectrical is offline   Reply With Quote
Old 02-26-2013, 06:12 PM   #2
Rewards Points: 1,418
They're fundamentally the same in that they both have a primary winding, a secondary winding, and magnetic framing called the core on which the windings are placed. They differ in physical size of the various components including wire thickness, and number of turns of wire around the core, and this is optimized for the current the transformer is supposed to carry and the supply voltage and the desired output voltage(s).
Some years ago I was talking to an electric company line man about transformers. I forgot exactly what he asked me but I started explaining about primary and secondary. He interrupted me and said that there are no coils inside the (distribution) transformer, it's just filled with oil. Since he worked with the things and I didn't, I did not bother to argue with him even though he was dead wrong. I suspect that all he knew is that you feed in 7000 volts or so and get out 120/240 volts. Now I had worked with small transformers like furnace transformers and I know that they have coils.
Old 02-26-2013, 07:43 PM   #3
Electrical Contractor
kbsparky's Avatar
A few hundred Amps ....
-KB
The Following 2 Users Say Thank You to kbsparky For This Useful Post:
stickboy1375 (02-26-2013), Stubbie (02-26-2013)
Old 02-26-2013, 10:02 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Your asking numerous questions and if you don't respond your not going to get much from here ....
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-27-2013, 12:09 AM   #5
" Euro " electrician
frenchelectrican's Avatar
Not much differnt beside the size and voltage/Kilowatts class.
This is pretty wide denifenation to use due there is many way to describe it.
Merci,
Marc
wiring furnace transformer jasonbaur HVAC 4 10-26-2012 04:44 PM
interlocking bath fan with furnace using relay and transformer drmclovin Electrical 6 02-02-2012 06:30 AM
No power from Furnace to transformer for HUM bwalbany HVAC 2 01-15-2012 02:25 PM
checking transformer voltage-Heil gas furnace chuck59 HVAC 0 09-07-2011 04:39 PM
transformer and circuit brd in gas furnace gulley HVAC 5 11-22-2010 12:48 AM
