#1 |
Dielectric sealant
I have a indoor/outdoor thermometer, and the sensor that runs outside became disconnected. I soldered the leads back on, but the sensor was embedded in some sort of clear sealant inside of a plastic casing. I tried regular silicone caulk, but that caused the temp to spike, so that's a no go. I'm imagining I need some sort of special dielectric sealant, but I have no idea what or where to get it. Any help would be appreciated!
Mike Last edited by gogo97gti; 02-21-2010 at 06:58 PM. |
#2 |
Electrical Contractor
Dielectric sealant
did the temp stabilize once the caulk finished curing?
-KB Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
retired elect/hvac/plumb
Dielectric sealant
stick it under the housing where your control wiring on your hp is to protect it from weather,should be fine
#4 |
Dielectric sealant
Maybe try some epoxy . kerry
#5 |
Dielectric sealant
Didn't let it cure. It was obvious that the caulk was having some sort of insulating effect that made the temp go up.
I want to make sure the stuff I use is right because there's no way I'll be able to dig it back out of dried epoxy if it doesn't work. I want to try to avoid having to buy another sensor. I believe that the main reason for the sealant was for moisture protection. The stuff that I dug it out of originally was clear. |
| Display Modes | |
| Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! | flipjarg | Flooring | 3 | 02-15-2010 10:09 PM |
| Question about pipe sealant and | simply derp | Appliances | 2 | 05-04-2009 11:25 PM |
| Epoxy roof sealant over shingles? | P550 | Roofing/Siding | 15 | 04-11-2009 11:00 PM |
| Ridge vent effectivenes and sealant | JDLowder | Roofing/Siding | 4 | 06-05-2008 11:42 PM |
| Paint Sealant For Wood | CommMajor101 | Painting | 6 | 07-24-2006 12:12 AM |
