Did Something Wrong Need Help - Electrical - DIY Chatroom Home Improvement Forum
Old 02-01-2008, 09:31 PM   #1
Did something wrong need help
the motor went out on my central air so i installed a new one - when i turned it on it blew the fuse in the disconnect box
the only difference between the motors wiring was that the old one had a white wire and the new one has a blue wire
was is supposed to be wired differently then the old one??
any help would be helpful
i had some one come out to look at it and instead of replacing the old motor he just changed the speed on it to make it work - i'm kinda P.O.ed because he took a short cut and now i have to do what he should have done to begin with
blowmax10 is offline   Reply With Quote
Old 02-01-2008, 09:38 PM   #2
Alpha Kennybody
HUH?
You swapped out the motors and it blew a fuse.
You call a guy, he changes the speed...that he should have done the first time???
Alpha Kennybody is offline   Reply With Quote
Old 02-01-2008, 09:48 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
I have NO idea what all this means. Is there a question in there somewhere?
Old 02-01-2008, 10:06 PM   #4
the question is - did i wire in the motor wrong
the guy changed the speed on the first motor
Old 02-01-2008, 10:16 PM   #5
Alpha Kennybody
I'm still confused...
The motor went out(#1)....you replaced it(#2)...a fuse blew
Guy comes over...swaps the motors(#2 -> #1)...and changes the speeds
Is that it?
Old 02-01-2008, 10:18 PM   #6
Lic. Master Electrician
I don't think you'll get a decent answer without giving more info.
idoelectric is offline   Reply With Quote
Old 02-01-2008, 10:22 PM   #7
Could be that your old motor had / has more than one speed. One speed died. Switching to the other speed allowed it to run again using different windings in the motor.
4thtbird is offline   Reply With Quote
Old 02-02-2008, 03:02 AM   #8
" Euro " electrician
frenchelectrican's Avatar
Just want to head up becarefull when you change the fan speed it will affect the performace of the unit.
Merci, Marc
Old 02-02-2008, 10:33 PM   #9
ok - first i called the guy - he changed speeds on the old motor and it worked for a day then died - so i bought a new motor
the new motor wiring was different - i wired it in wrong - a friend from work came over and fixed it
his solution was quite interesting - he just moved the wires around until it worked - it took 3 buss fuses but it is now working
and yeah i know i need to change the old disconnect out - buss fuses are bad
Old 02-02-2008, 11:15 PM   #10
Wow. The old "keep blowing fuses 'til you get it right" theory.
Wonderful.
Old 02-03-2008, 08:39 AM   #11
Rewards Points: 1,500
Just trying things until the motor worked and fuses did not blow was not a good idea. You could have damaged the motor.
The blue wire and lack of a white wire suggests to me that the motor is for a three phase power supply but you have a single phase power supply.
If there is a diagram with little squiggly lines arranged in a triangle, chances are the motor is three phase.
Old 02-03-2008, 09:27 AM   #12
Alpha Kennybody
It might help if you could actually create a time line for us to follow.....I have no idea what you are talking about.
Are we up to 3 motors now?
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Ants and avoidance of baits - what am I doing wrong!? joeyboy Pest Control 11 01-14-2008 09:09 PM
Drywall,what am I doing wrong? Feangel Painting 4 06-19-2007 08:17 PM
Whats right and wrong? eric s General DIY Discussions 19 05-09-2007 08:03 PM
Does this seem wrong? LRAO Electrical 6 01-24-2007 07:55 PM
