Did I Screw Up - Electrical - DIY Chatroom Home Improvement Forum
Old 07-01-2013, 11:01 PM   #1
did I screw up
Ok have a two gang switch box with 120 ran to it. Feeding a outlet for a fan/light combo in the kitchen.. I have 12/3 ran from plug box to switch. Can breaking the tabs off hot side of plug make the two switches work that outlet correctly?
tripleAelectric is offline   Reply With Quote
Old 07-01-2013, 11:07 PM   #2
An old Tradesmen
Rewards Points: 6,582
Moved to Electrical forum.
The Following User Says Thank You to beenthere For This Useful Post:
tripleAelectric (07-01-2013)
Old 07-01-2013, 11:28 PM   #3
Rewards Points: 150
Is this for an exhaust fan like in a bath or is this a hood?
RIP EJT
usair is offline   Reply With Quote
Old 07-01-2013, 11:32 PM   #4
For the kitchen. Was told their needed to be two separate switch for each. So put on plug in at 76" and ran 12/3 to the switch.
Old 07-01-2013, 11:51 PM   #5
Rewards Points: 150
Who told you? I see a potential code violation. A hood must be on an individual circuit that also means a single outlet so you cant use a duplex.
RIP EJT
Old 07-02-2013, 12:02 AM   #6
So a hood vent combo. Cant be two separate outlets off the unit? This is residental stuff ive never done before. The hood isnt pulkibg much amps neither is lite
How to screw in a gutter mj12 Roofing/Siding 2 06-28-2013 10:16 PM
is ground screw on light switch necessary SS396 Electrical 17 01-12-2013 04:48 PM
What type of nails/screws should be used with furring strips? firsttimeremode Building & Construction 18 10-02-2012 09:30 AM
screw type bulbs. mpj111 Electrical 5 01-27-2009 04:27 PM
Screw and plug 5/4" PTP decking Klaus Building & Construction 3 06-10-2008 08:01 AM
