Diameter Hole For 4 * 12/2 MC - Electrical - DIY Chatroom Home Improvement Forum
Old 05-07-2008, 02:29 PM   #1
Rewards Points: 270
Diameter hole for 4 * 12/2 MC
Is there somewhere I can find out the proper hole diameter through a joist, and/or max # of wires per hole without derating?
pcampbell is offline   Reply With Quote
Old 05-07-2008, 03:19 PM   #2
Registered User
Termite's Avatar
In the I-codes, holes can be drilled through joists. The holes must not exceed one third of the joist's depth, and must not be any closer than 2" to the top or bottom chord.
As far as wiring goes, you need to avoid bundling. I'd have to dig for code language to substantiate this, but I'd limit it to 2 or 3 wires per 1" hole. The less, the better. Drilling a few smaller holes a few inches apart will always be the best way to go, as opposed to pulling several wires through the same hole.
Old 05-07-2008, 03:38 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Up to four cables before you need to be concerned about derating.
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 09:35 AM
12/2 diameter question mark942 Electrical 5 04-18-2008 10:25 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Fixing 11" Hole in Concrete Foundation robertr4836 Building & Construction 6 02-04-2008 08:08 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
