Diagram For Small Can Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 11:33 AM   #1
Diagram for small can lights
I do not know a lot about electrical.
I ran Romex from a switch to can1 then to can2 then to can3 then to can4 and the wiring terminated at the 4th can. Now the 4th can light keep burning out.
Was I supposed to complete the loop or something? I am not sure what is occurring. any help would be appreciated.
mackdoyle is offline   Reply With Quote
Old 05-22-2011, 12:10 PM   #2
joed's Avatar
Rewards Points: 12,356
If it goes on and off with the other lights and is normal brightness then you wired it proper. Something else is wrong.
Old 05-22-2011, 12:15 PM   #3
OK thanks. It does indeed. Maybe there is a problem with the can itself.
Old 05-22-2011, 03:42 PM   #4
Lic Elect/Inspector/CPO
What size bulb are you using?
What type trim on the light?
Bulbs can burn out for some diffenet reasons.
Inside of fixture get to hot make sure bulb being used is correct for fixture and trim.
If you can get them try bulbs rated for 130 volts
NJMarine is offline   Reply With Quote
Old 05-22-2011, 07:07 PM   #5
It's a Utilitech 3" Non IC Housing Brushed Steel Recessed Kit. I have a 50w halogen in it.
Here is the housing:
http://www.lowes.com/pd_16616-47842-...d|1&facetInfo=
Old 05-22-2011, 07:45 PM   #6
IBEW Electrician
It may be the can light itself, generally halogen fixtures have small transformers inside the fixture so it could be a bad transformer causing your light to burn out... also NOTE make sure when your changing a bulb you are not touching it with your bare skin or you will get oil on it causing it to burn out MUCH faster because of hot spots. If your changing the same lamp over and over with your fingers directly on it that could be causing it to burn out faster... two things to look into.
Scott3229 is offline   Reply With Quote
Old 05-22-2011, 07:47 PM   #7
OK, thanks. Ill check into the transformer. I make sure not to touch halogen bulbs when installing.
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Pot lights wiring diagram Eaglenest Electrical 5 03-29-2010 12:09 PM
check my wire diagram please. thanks! fabian Electrical 8 01-04-2009 11:32 AM
Wiring diagram for lights with two switches Ed M Electrical 7 08-10-2008 08:59 AM
Wiring diagram, would this work firemanpato Electrical 10 01-07-2008 04:33 PM
