This Diagram Look Ok? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2010, 05:28 PM   #1
Just call me Andrew
Rewards Points: 1,020
This diagram look ok?
Two sets of basement lights. I'd like a 3-way for each light group, at each end of the stairs. I plan to use double-3ways if i can legally fit all the wires in a single-gang box. Otherwise I'll use two separate 3-ways in each spot. Only thing I am wondering about is using only one 3-conductor wire between the two boxes, and using its white conductor for both light groups. I think it's ok...is it?
Thanks!
PS. If anyone wants to fix my typo in the subject, please do.
Andrew
secutanudu is offline   Reply With Quote
Old 03-29-2010, 06:01 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
there has to be 2 wires that run between the 3-way each set of switches. That is a must. You cannot intermix the wiring from one switch group and the other.
The 3rd terminal on the switches; on one switch, it would be the hot feed from the panel, on the other switch (the other end of that particular switch set), it would be the switchleg to go to the lights.
Obviously the hot can be common to more than one switch if needed but the switch leg is the switch leg.
If you use a common hot circuit to feed two sets of switches, you will have 6 wires between the 2 sets of switches (presuming both sets of 3 ways are in a common location). 4 would be travelers, 1 would be your neutral, and one the ground (EGC).
Old 03-29-2010, 06:32 PM   #3
Master Electrician
Rewards Points: 3,750
Not the way I would do it but it should work fine the way it is drawn.
brric is offline   Reply With Quote
Old 03-29-2010, 07:18 PM   #4
joed's Avatar
Rewards Points: 11,994
As long as the power feed and light feed is the common screws it should work fine.
Old 03-29-2010, 09:27 PM   #5
Just call me Andrew
I forgot to label the common screws, but they are the hot feed and the feed to the lights (They are black in the diagram). I just wanted to make sure it was ok that both lights share the one neutral in the 14/3 between the switches, that way the other switches could have 14/2 instead of 14/3.
I omitted the ground wires, they will of course be run as well.
How would you do it?
Andrew
Old 03-29-2010, 10:14 PM   #6
Master Electrician
Probably would need a deep 4 square box with a mud ring but I would take the power to the box on the right, 2 3-wires between the switch boxes.
Old 03-30-2010, 08:40 AM   #7
Just call me Andrew
Problem I just thought of. The feed to the existing switchbox is BX cable. I don't think I'll be able to use the current single gang metal box, I'll need to replace it with a 2-gang and use two switches.
Is there a clamp/connector to connect BX cable to a ground wire so I can run it into a plastic box and ground my devices to the wire? Thanks.
Andrew
Old 03-30-2010, 08:52 AM   #8
Master Electrician
As a rule mettallic systems are not used with plastic boxes. There is no equipment ground inside BX cable. The armor itself is the grounding means. Is there a reason not to use a new mettallic box?
Old 03-30-2010, 08:54 AM   #9
Just call me Andrew
Are old-work metallic boxes easy to find and install?
I figured they'd make some sort of clamp you could put on the outside of a BX cable, then attach a ground wire to it. I was thinking something like the type of clamp you use to attach a ground wire to a water pipe.
Andrew
Old 03-30-2010, 09:36 AM   #10
Master Electrician
Not an accepted practice. I guess you could install a bonnding bushing but there is no need to if a proper connector is used and lock nutted to a metallic box. Lowes, Menards, HD should have deep metallic boxes that could be used with madison straps for old work.
Old 03-30-2010, 09:45 AM   #11
Just call me Andrew
Googling "Madison strip" gives me...lots of gentleman's clubs...What are they?
Andrew
Old 03-30-2010, 09:49 AM   #12
Master Electrician
Try madison straps.
Old 03-30-2010, 09:52 AM   #13
Just call me Andrew
Ha, thanks
Andrew
Old 03-30-2010, 09:54 AM   #14
Master Electrician
Old 03-30-2010, 02:35 PM   #15
nap
You talking to me?
nap's Avatar
what is what? gentleman's clubs?
you really are young, aren't you?
there are metal old work boxes with integral clamping features as well quite similar to the plastic old work boxes. For a non-pro, I tend to suggest not using madison straps. While not really rocket science, there are a few tricks to using them that come with time. If you are installing just a few boxes, I would recommend old work boxes with integral clamping provisions.
and as an explanation for my first post. I did not realize secantudu was showing 2 switches in each box and without glasses on, the wiring was not clear to me .
Upon looking at it when I can see it clearly: it looks just fine with the one exception of the EGC not shown but obviously required.
check my wire diagram please. thanks! fabian Electrical 8 01-04-2009 12:32 PM
need detailed photo or diagram butlersprints Plumbing 9 11-30-2008 09:31 PM
wiring diagram question screenporch21 Electrical 10 11-30-2008 09:14 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
Does this wiring diagram work? beezlebub03 Electrical 7 05-05-2008 12:54 AM
