Diagram Of A Ceiling Fan Light Bypass - Electrical - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 11:30 AM   #1
Diagram of a ceiling fan light bypass
Anyone have a diagram of a ceiling fan light pull chain. The pull chain is bad and I want to bypass it. It is a Hampton Bay ceiling fan.
McCabe29 is offline   Reply With Quote
Old 12-06-2010, 02:23 PM   #2
Mad Scientist
The light switch should only have two wires on it. Wirenut them together.
Otherwise, a replacement pullchain switch should be available at any hardware store for a few bucks.
McSteve is offline   Reply With Quote
Old 12-06-2010, 02:34 PM   #3
Trying to avoid going to the hardware store. The fan works its just the lights that dont work I want the wall switch to controll the light hence the bypass but im not sure witch wires to connect together. There are three wire coming from the light pull chain red, blue, and black.
Old 12-06-2010, 02:40 PM   #4
Rewards Points: 459
If you find the wires going into the pull chains switch & wire nut these two wires together, you'll bypass the switch.
edit: are you looking at the fans pull chain? That would explain multiple wires (multiple fan speeds). The light should just be a line and a load.
Nick DIY is offline   Reply With Quote
Old 12-06-2010, 03:08 PM   #5
There are three wires coming out of the light pull chain red, blue, and black. There are 4 coming out of the fan pull chain black, yellow, orange and purple.
Last edited by McCabe29; 12-06-2010 at 03:22 PM. Reason: 4 wires coming out of the fan pull chain
Old 12-06-2010, 03:14 PM   #6
Mad Scientist
That's odd. How did the original switch work? Was it just on-off, or were there two separate sets of lights? Or two brightness levels?
I'm afraid I'm not quite sure what to tell you. You might have to try and figure out where each wire is connected inside the fan, or maybe just experiment a bit...
Old 12-06-2010, 03:23 PM   #7
Just my luck. Just an on-off switch. Thanks.
Old 12-06-2010, 03:24 PM   #8
Rewards Points: 459
Which does the hot lead hook into? I'd jump hot to either red or black and see if that works.
Or are there multiple light fixtures? Maybe they junctioned them in the switch?
Old 12-06-2010, 03:31 PM   #9
Hot runs into the kit connection and red and blue hook to the lights.
Old 12-06-2010, 03:38 PM   #10
Rewards Points: 459
Do you have a continuity or ohm meter? Check for continuity from the wires to the inside of the light sockets (with power turned off, of course). This will tell you which are your light leads.
Old 12-06-2010, 03:47 PM   #11
Ok thanks.
Old 12-06-2010, 04:22 PM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,172
You have a light kit with multiple lamps. The switch acts like a 3 way light lamp fixture; Off/ 2light/ 4lights. If you bypass the switch all 4 lights will light when you turn on the wall switch. If this is what you want, cut the leads off the switch and wire nut all 3 wires together.
Coastal South Carolina
Old 12-06-2010, 04:39 PM   #13
Thats exactly what I want im gonna try it thanks.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 08:32 AM
Help- cant get a new ceiling fan light to work boddabing Electrical 6 08-26-2010 05:24 PM
Trying to install a new ceiling light in an old house Yikes Electrical 2 07-25-2010 11:49 PM
Ceiling light abuse! shurik57 Electrical 5 11-26-2007 10:30 AM
