Old 11-13-2007, 01:40 PM   #1
diagnosing arc fault problem
I have a 15 amp arc fault breaker at the main panel for my master bedroom lights and receptacles that keeps going off. I narrowed it down to a light switch that I have replaced and changed my light bulb. The breaker goes off when I try to turn the light on. Where do I check next?
twilson is offline   Reply With Quote
Old 11-13-2007, 02:14 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
If this started happening when you changed that switch you either have a short created when you wired the light or you have a neutral or hot wire touching the ground wire , metal box or each other. Check to make sure you don't have this situation. If it is in the switch box it is the switched hot wire, otherwise it could be any wire in the fixture box.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 11-13-2007, 10:23 PM   #3
remove bulbs from fixture turn switch on see if breaker still trips .
if not your wiring is probably ok.What brand breaker?I have had
at least 6 new seimens arc fauts bad out of the pack.
GREGNC is offline   Reply With Quote
furnace problem captjack HVAC 8 11-23-2007 12:15 PM
1994 camry rear suspension/tires problem marks5894 Automotive Repairs 2 11-05-2007 06:12 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
