Old 01-27-2008, 09:10 PM   #1
Power Gen/RS Engineer
Device Box used as Junction Box
As long as the requirements of 314.16 are followed, is there any reason why a device box cannot be used as a junction box (with no devices contained therein)? I have a location where I'd like to install a junction box however I do not have enough vertical space between the basement ceiling and some conduits running about 3 inches below. I have some left over 4x2x2 switch boxes any of which would fit perfectly in this space if horizontally-mounted.
I did have to whack out a portion of the ceiling to fish some thinwall up through the floor and I could install a 1900 box protruding slightly into the ceiling. But, if I get around to patching the hole, this box would then be partially buried in the ceiling which I would assume is a no-no.
TTFN,
Jimmy
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Old 01-27-2008, 09:18 PM   #2
Put all the Jboxes you want.
Just don't bury them
220/221 is offline   Reply With Quote
Old 01-27-2008, 09:59 PM   #3
So, the fact that this is really a device box is not an issue? OK for use as a junction box only?
Thanks!
Jimmy
Old 01-27-2008, 10:08 PM   #4
Electrical Contractor
Thanks!
Jimmy
Just make sure you put a cover on it!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
Old 01-27-2008, 10:29 PM   #5
12 year IBEW member
and watch you conducter fill in a the box,
heavyduty is offline   Reply With Quote
Old 01-27-2008, 10:37 PM   #6
That was my reference to 314.16 and I'm all over it! This is simply a place to splice off another recept for a different part of a room but all said, yes, I'm paying attention to conductor count. Thanks!
No problem, I always do!
One question: Do they make flat covers for these boxes, like those available for 1900's and 4-11's? The ones that I've always seen have bevelled edges that usu. hang over the sides of the box and are substantially thinner than the gauge of the metal comprising the box.
Thanks guys,
Jimmy
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 10:30 AM
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 09:40 PM
Junction Box Wiring Question mattbing Electrical 3 12-03-2007 11:49 PM
Old House - no junction box - HELP! Designman20 Electrical 22 10-11-2007 05:58 PM
