Old 12-18-2008, 08:51 PM   #1
Device Box Size For GFCI
Hey All,
Is there a minimum device box size for GFCI's? I have an old house and the device box is damn small - so small I almost have to smash with my hand to get the GFCI to fix in the box. I want to replace the box with a larger size so the GFCi fits nice and the conductors are not crushed/smashed as well.
Thanking you in advance.....
icepal1999 is offline   Reply With Quote
Old 12-18-2008, 08:53 PM   #2
Electrician
Originally Posted by icepal1999 View Post
Hey All,
No, but if the box is way to small use a gfci breaker. Or replace the box with more cubic space.
chris75 is offline   Reply With Quote
Old 12-18-2008, 09:08 PM   #3
Yeah I want to replace the box - is there a min size - say 18cu or 21cu?
Old 12-18-2008, 09:32 PM   #4
It was a dark and stormy
Yoyizit's Avatar
My local Code people said a GFI does not require a larger box, but I had the same problem as you.
Logically, a bulky GFI seems to violate single gang box fill requirements if box fill is based on
free air circulation within the box and
current through the wires in the box and
not wanting to damage conductor insulation.
Before you buy the Old Work box, check if you have 3-1/2" depth or 2-1/2" depth between drywall surfaces. Some interior partitions use 2x3s.
Old 12-18-2008, 10:07 PM   #5
Electrical Contractor
How many wires in the box?
2 sets of wire, use the 18 cu, 3 sets of wire use the 21 cu box.
There is not a min, but you do not want to crush the wires.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Size of whole house fan needed Doug Crf General Discussion 20 02-26-2011 12:29 AM
duct work size justmefixin HVAC 2 09-20-2008 07:59 PM
What type / size screws for subloor project... scheenstra Building & Construction 1 05-17-2008 09:22 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
