Determining Wattage Usage Of Electronics - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 06:11 PM   #1
Question
determining wattage usage of electronics
I'm familiar with the amps x volts = watts. On many electronics, however, it gives a range for the volts, maybe 100-240 volts and then something like 1 amp for the current. Is this saying that the wattage in, say, Africa is higher than in the US? If it pulls 1 amp no matter, then would it be 120 watts (120 volts x 1 amp) in the US and 240 watts in Africa (240 volts x 1 amp)?
Thansk!
greenlivn is offline   Reply With Quote
Old 01-02-2010, 06:23 PM   #2
It pulls whatever power it needs and tolerates a wide range of input voltages. The wide range implies that it is a switch-mode power supply, as opposed to a linear supply.
You could infer that the max power draw is 1A(120v) = 120 w and the current draw would probably be a half amp at 240v.
Old 01-02-2010, 08:05 PM   #3
Idiot Emeritus
Rewards Points: 1,476
Actual watts of any AC device is Volts X Amps X Power Factor.
Both linear and switching power supplies usually have horrible power factor. Somewhere around 20-50%. Power Factor usually goes lower as voltage increases. Some are corrected, but usually only large ones (over 1 KW).
The only way to know for sure is to use a watt meter, but it's pretty safe to assume the Power Factor to be 50%.
In the above example, it'd be pretty safe to assume that a device marked 100-240 volts and 1 amp would consume less than 60 watts, more like 40.
A better way is to look at its DC output. Say it's 12 volts and 2 amps. That's 24 watts (Power Factor has no effect on DC circuits). Figure about 25% more, and you're pretty close to the input power. In this case, it'd be about 30 watts.
The input amp figures on power supplies are notoriously inaccurate.
Rob
micromind is offline   Reply With Quote
Tags
amp , current
Getting small shock from household electronics cases (in Asia). Why? scootley Electrical 16 11-11-2009 10:09 PM
Amps vs wattage moneymgmt Electrical 8 05-30-2007 07:13 PM
