Determining Panel Amp Load Capacity - Electrical - DIY Chatroom Home Improvement Forum
Old 11-24-2011, 09:56 AM   #1
Rewards Points: 152
determining panel amp load capacity
I searched and searched but came up empty.
How can you determine the amp load rating of any panel that has lost its paper placarding information? Over the years the labels crumble, become eligible, and/or fall off and there is nothing to indicate capacity or even a mfg model number. It is just a faded gray box with a wiring buss in it.
David
n175h is offline   Reply With Quote
Old 11-24-2011, 09:57 AM   #2
Rewards Points: 766
post a picture of it
carmusic is offline   Reply With Quote
Old 11-24-2011, 10:44 AM   #3
Rewards Points: 152
No particular panel in general.
I've opened panels in not necessarily old buildings that have no paper markings in them. This is especially true if the panel is on the sunny side of the building and is being cooked by heat. the paper label is a pile of fibers that falls out when you open the panel door.
David
Old 11-24-2011, 11:04 AM   #4
Rewards Points: 254
I would guess it will handle whatever the main breaker is.
cjm94 is offline   Reply With Quote
Old 11-24-2011, 11:40 AM   #5
Sfeyelectric's Avatar
Should be on the main breaker handle
Sfeyelectric is offline   Reply With Quote
The Following User Says Thank You to Sfeyelectric For This Useful Post:
n175h (11-26-2011)
Load Capacity of driveway - Will a dump truck crack it? Deavis Building & Construction 17 03-29-2015 08:43 AM
Wiring a sub panel to another sub panel Uncle Wayne Electrical 25 02-08-2011 09:50 AM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 12:43 AM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 03:35 AM
Passing wire to another panel theatretch85 Electrical 5 09-20-2009 11:09 PM
