Detecting Hot Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 01-11-2009, 06:45 AM   #1
Phil
Detecting Hot Wires
I am converting to rocker swtiches and found out some of my hot wires are white and others black. Is this normal?
I thought White was suppose to be wired to the power source. Red always seems to be a traveller.
Thanks for your help.
psdipietro is offline   Reply With Quote
Old 01-11-2009, 07:30 AM   #2
White can be part of a switch loop also. Are you using a cricket(audible detector)?? They often read eroneously.
Old 01-11-2009, 09:10 AM   #3
Phil
I am just using a circuit tester light. The switches are 3 ways. You are probably right, the white is part of a switch loop.
Old 01-11-2009, 01:05 PM   #4
Rewards Points: 1,512
White can be a traveler or the hot feed to a switch. This means that there is no standard for 3 way switch loop wiring color. White may not be the switched line to the light or other load.
Neutrals must never be switched. Therefore white to a switch is assumed to not be neutral. Non-neutral white wires need to be tagged at both ends with a band of red or black tape or stain.
A nearly (not 100%) reliable method of finding a hot lead is to test its voltage to ground.
Old 01-11-2009, 04:21 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
For quick checking the presence of AC voltages I use a Voltage sniffer.
These use a non-metallic plastic tip probe so it is not necessary to contact metal. The probe will light up and beep when held close to an AC source.
The El-Cheapo 70-1000VAC model: HF Non-Contact Voltage Tester
The sniffer that I prefer is adjustable from 5-1000 VAC so it can be used on low voltage lights, door bells, and thermostat wiring.
Greenlee GT-16 - Non-Contact Adjustable Voltage Detector, AC 5-1000V
The precaution is that like digital voltmeters they can give false positives.
To verify AC voltage rather than using a DMM I prefer a WIGGY, because of its low input impedance will not read phantom voltages as seen sometimes on DMMs.
Klein Tools: Electrical Testers - Wiggy Solenoid Voltage Tester
The name Wiggy is copyrighted so here is the Gardner Bender copy:
Gardner Bender at Lowe's: Solenoid Voltage Tester
Detecting Hot Wires-hf-tester-97218-9vga.jpg   Detecting Hot Wires-greenlee-gt-16-1st.jpg   Detecting Hot Wires-wiggy-gb.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Tags
common vs traveller
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Heil DC90 - AC Wires keithshank HVAC 1 07-31-2008 08:37 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 02:55 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
