Detached Shed Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-17-2009, 05:50 AM   #1
Detached shed wiring
I have a shed, approx. 100' from my house. The electric I plan to run to it will be running a few lights, a couple shop tools, and possibly a window AC unit or space heater. Do I need a subpanel in the shed, or can I just run a couple circuits from my main house panel?
sketh24 is offline   Reply With Quote
Old 02-17-2009, 06:08 AM   #2
You need a subpanel. From the sound of what have already planned, this will end up being more than one circuit.
Old 02-17-2009, 03:13 PM   #3
You CAN run two circuits (max) but for the little added expense , I would put in a sub panel. Electricians generally overkill everthing because we are always being asked to add more power.
30 amp sub on #10 wire= minimum.
50 amp sub on #8 wire= better
60 amp sub on #6 wire= best
4 wire system. 2 hots, 1 neutral, 1 ground, 1 ground rod w/#6 to sub. Neutral bus isolated from panel enclosure, ground bus attached to enclosure.
If you do decide just to go with 2 circuits, use #10 wire minimum for the feed. 100" is a long run and you want your power tools to operate properly..
220/221 is offline   Reply With Quote
Old 02-17-2009, 04:32 PM   #4
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
I just did a 30A sub for my parrents garage exactly as described here. I used a small square d panel I had laying around. It was a 6 position panel. I installed a 60A breaker and a hold down. Then installed 2 other breakers to feed the garage.
The panels like the one I used are about $15 - $20 plus breakers. You will have to put in a ground bar and a breaker hold down.
I would install larger than 30A for a garage / shed that tools will be used in.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Wiring Diagram for Detached Garage jamiedolan Electrical 0 02-07-2009 09:43 AM
Wiring new detached garage/studio WShawn Electrical 4 07-21-2008 06:13 PM
Wiring a well pump in the shed diyjet52 Electrical 5 07-11-2008 12:39 PM
Help with wiring in shed sandyman720 Electrical 1 06-25-2008 11:11 AM
Shed Wiring bcdal Electrical 12 03-26-2008 04:51 PM
