Detached Garage Subpanel Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2013, 08:13 AM   #1
Question
Detached Garage Subpanel wiring
I have 220/40 amp UV and underground rated wire 18" deep run to my new garage in Lake County Minnesota. Hopefully you fine professionals can answer a few questions before I drill a hole through the side:
Is there a height from ground requirement for my schedule 80 to enter the structure?
Is there a height requirement for the sub-panel inside the garage?
Once through the wall must the feed line enter through the rear of the sub panel or can it feed through the bottom of the panel?
Once inside, must the portion of the line also be encased before entering the sub-panel or can it be simply secured with a panel clamp?
Is there an upside down for the panel? Can it be mounted with the Main breaker at the bottom of the box?
I appreciate and humbly bow to those offering wisdom on the subject...
Finlandbob
finlandbob is offline   Reply With Quote
Old 08-27-2013, 08:23 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
NO!
Either or.
Is it a cable or individual conductors? If it is a cable, the it does not need to be in pipe.
Some do, some don,t.
Finlandbob
Did you run 3 wires and a ground out to the garage?
You also need 2 ground rods at the garage, and make sure you separate the grounds and neutrals in the panel.
The Following User Says Thank You to jbfan For This Useful Post:
finlandbob (08-27-2013)
Old 08-27-2013, 08:27 AM   #3
Licensed electrician
Rewards Points: 1,892
If the breaker operates horizontally there is no upside down. If it does not, UP needs to be ON.
wiring detached garage psteinberg Electrical 3 12-09-2011 04:50 PM
Wiring a detached garage from another detached garage? bhawghead Electrical 7 05-25-2011 12:54 AM
New detached garage, wiring, questions gp_wa Electrical 9 12-04-2008 03:10 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
help wiring detached garage to code ugabulldog Electrical 7 08-05-2008 08:48 AM
