Detached Garage With A Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2009, 03:21 PM   #1
Rewards Points: 1,062
detached garage with a subpanel
does a detached garage with a subpanel and supply coming from the house need a lightening rod ? which gauge cable do you use to run a lightening rod to the ground ?
Old 03-24-2009, 06:00 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
2 of them at least 6' apart and #6 copper.
wirenut1110 is offline   Reply With Quote
Old 03-24-2009, 06:03 PM   #3
thanks. any example diagram how i should put it all together ?
Old 03-24-2009, 06:07 PM   #4
and also, how deep should i go burying the grounding ? is a couple feet ok ?
Old 03-24-2009, 06:07 PM   #5
Rewards Points: 510
Just drive the 2 rods, run the #6 continuous through the 2 and land them on your ground bar in your panel.
I usually go through the first pulling enough to make it to the 2nd one and the rest back up in the panel.
Old 03-24-2009, 06:09 PM   #6
Rewards Points: 510
If your talking about the ground wire between the 2 rods, I just take the claw of my hammer and dig a little trench just to have it underground or secure to the structure.
PS. Drive your rods flush with the ground, be sure to put the clamps on first because the ends flare out and you won't be able to get them on. Also, if it's getting inspected, I'd put some spray paint on the ends so the inspector can find them.
Old 03-24-2009, 06:14 PM   #7
i am actually talking about a diagram that shows everything, the stick on top of the building and how it is connected to the subpanel and the rod that goes into the ground.
Old 03-24-2009, 06:17 PM   #8
Rewards Points: 510
Oh, I though your were talking about ground rods for your subpanel..
Old 03-24-2009, 06:20 PM   #9
Rewards Points: 510
See if this helps
http://www.mrlightning.com/files/diagram-r.jpg
Old 03-24-2009, 06:26 PM   #10
thanks, it does. so my only question left is should the cable from the air terminals run on the outside of the shed or the inside ? i would guess outside. if inside, my question is at which point does it go outside to go into the grounding rod ?
Old 03-24-2009, 06:27 PM   #11
Rewards Points: 510
I would say outside.
detached garage subpanel help edmart2 Electrical 7 03-19-2009 01:01 PM
Legal to have subpanel in garage? gante Electrical 36 03-13-2009 04:27 PM
Subpanel - detached garage without a floor SAS Electrical 12 03-05-2009 12:42 PM
Subpanel in detached garage gp_wa Electrical 6 10-07-2008 10:11 PM
Grounding for detached all-metal garage geeswanie Electrical 3 07-03-2008 08:31 AM
