Old 10-09-2012, 09:19 PM   #1
Detached garage sub panel - connection from outside to panel
Hello
I ran a 2" conduit for my detached garage subpanel and have an LB connection on the outside that I ran through the wall to the inside. My problem is that the sweeping 90 elbows are too big to fit in the 2x6 wall cavity so I thought I could buy some smaller ones (similar to plumbing PVC), but it seems they don't make anything that will work. The sub panel is mounted to the wall about 2 feet above the wall penetration. I should have thought ahead and penetrated the wall so it met up with the back of the panel, but I didn't think about it until I went to fit the sweeping 90 elbow and saw that it wasn't going to work.... oops!
I'm guessing it wouldn't pass inspection if I just run the wires (2-2-2-4 URD AL) to the panel and not have conduit the whole way inside. So it seems like I need a solution for conduit to do a 90 degree turn in 4-5 inches. Since this is going to be behind drywall I was thinking of using another LB connector and then making sure there's an access panel there just in case. Unless somebody has any better ideas?? I also have to do the same thing for the other end of the conduit, but there I couldn't have come in directly behind the box since the electrical meter is there so I would have ran into this problem anyways. Thanks in advance!!
BrianDC is offline   Reply With Quote
Old 10-09-2012, 10:53 PM   #2
Another LB and length of PVC with an adapter is the way I would go.
Old 10-10-2012, 07:59 AM   #3
Lic Electrical Inspector
electures's Avatar
Can you LB directly into the back of the panel?
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 10-10-2012, 10:21 AM   #4
When my brother-in-law built his garage, the electrician did this. The LB on the inside is set in the wall. They put an access door in front of it.
brgmgb is offline   Reply With Quote
Old 10-10-2012, 02:04 PM   #5
Move outdoor LB up. Patch lower hole in wall.
Oso954 is offline   Reply With Quote
Old 10-13-2012, 10:18 PM   #6
Thanks for the replies everyone! I haven't finished it up yet, but picked up a few more LB's at the store today. I think I'll just route it along that way and make sure there's access to it. The basement one will have an access door anyways so no biggie for the garage too.
Old 10-13-2012, 11:19 PM   #7
Licensed Electrician
k_buz's Avatar
I don't use URD, but from what I've seen, I'm not sure URD is rated for indoor use. I could be wrong though.
Location...Location...Location
Old 10-15-2012, 03:41 PM   #8
Inspector seemed to think it was OK. It doesn't say URD on the cable, but that was the description when I bought it. I thought it stood for Underground Residential Distribution, but not positive. I saw somewhere that it's used for street lights as well.
The final solution I used was plugging the hole and re-running it directly to the back of the box. Ended up being the easiest solution and it's on the side of the garage right near a fence so nobody will see it. Thanks for the help!
Old 10-15-2012, 05:43 PM   #9
E2 Electrician
stickboy1375's Avatar
URD is just slang for USE type cable and must follow article 338.
Old 10-15-2012, 06:12 PM   #10
k_buz's Avatar
http://www.homedepot.com/buy/southwi...-55417301.html
The page is messed up a little, but if you scroll down to almost the bottom, you will see this particular URD is not rated for indoor use.
Detached Garage Wiring elpht_man Electrical 5 09-23-2011 07:31 AM
New detached garage with sub and ground, house has no ground at panel italie Electrical 9 09-12-2011 03:43 PM
Sub Panel to Attached Garage marly Electrical 4 06-02-2011 01:34 AM
WIring Detached Garage btedford Electrical 9 03-20-2011 09:09 AM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
