Detached Garage Ground Wire To House EMT? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-22-2010, 10:15 PM   #16
" Euro " electrician
frenchelectrican's Avatar
JohnD.,
If the OP want to go that route as you describe it will affect the conductor rating due you have more than 3 CCC's { Current Carry Conductors }.
I have to pull up a chart and crush the number a little to see how much derate it will affect the whole thing but as long the OP give us direct answer it will be not too bad.
But there a gotcha as I mention above when you have both detached and attached garages if you going to run 3 ways plus 4 way switch set up as far you should be aware with the code with MWBC going to detached garage so he have to start the power source at the detached garage and run from there.
The key issue is disconnect and numbers of circuits it will allowed.
Merci.
Marc
connecting ground wire to ground screw amakarevic Electrical 10 12-24-2008 05:28 PM
Enhancing existing wiring to detached garage justinperkins Electrical 46 07-07-2008 08:29 PM
Grounding for detached all-metal garage geeswanie Electrical 3 07-03-2008 08:31 AM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
running wire to detached garage amakarevic Electrical 2 02-28-2008 03:17 PM
