Old 01-01-2006, 10:45 PM   #1
Detached garage adding a 3 way switch.
I need you to dummy this down as much as possible. Please try not to make fun of me to bad. There is no power running to these now. I just left them up so I could take pics of them.
I got 3 switches that I want to operate my garage lights. My main switch is in the back of the garage by the door. It's a 3 way. My other switch is inside the house. It's also a 3 way. My 3rd switch I would like to add would be put in the front of the garage by the front door. this is also a 3 way.
I ran 14/3 cable from the switch in the back of the garage to the front switch and wired it up. I believe I did it correctly. Problem is when I flip the switches (not the one inside the house) the lights flicker. When I put either switch half way, (pointing straight out) the lights go out. Needless to say this isn't correct.
The wire I ran from the rear switch has 3 wires, red, black, white and ground. Do I need to go up to 4 way switches? Can I still use the 3 way wire and make this work? I'd hate to add another wire.
Here are some pics:
This is the front switch (the new one)
This is a second shot of the same switch
Here is the rear switch. The one I added to.
Second rear switch shot
Slatherd is offline   Reply With Quote
Old 01-01-2006, 11:06 PM   #2
World famous jerk.
Your rear switch is wired up wrong. You don't need to double up the connections, and you have the wrong switch installed there. You need to use a 4-way switch in that location. It will have 4 terminals, plus the ground screw. You will wire nut both black conductors together in that box. The red conductor from the black cable will go on one top terminal, and the white conductor from the black cable will go on the other top terminal. The red conductor from the white cable will go on one bottom terminal, and the white conductor from the white cable will go on the other bottom terminal.
Go out and get yourself a 4-way switch to put in there, and wire as I've described, and you'll be in good shape.
mdshunk is offline   Reply With Quote
Old 01-01-2006, 11:26 PM   #3
Excellent. I'll keep you posted.
I appreciate the help.
Old 01-02-2006, 12:17 AM   #4
I think I understand what you are talking about. Sorry for the crudeness of this drawing. Unfortunatly I dont have a better one.
This is my understanding of what you mean.
Is this correct?
Also, I forgot to add. I assume once I get th wires correctly put in the light will go on inside the switch? These say they are lighted, but I have yet to see them come on.
Old 01-02-2006, 03:53 PM   #5
Well, it worked just like you said. I wasn't able to find a lighted 4 way, but it works good.
Problem is, my inside switch only works when the new outside switched to the "on" position. when I flip it on, then the inside works for on and off.
What now?
Do I need to reverse the wires on the inside switch?
More On This Topic
In this clip, we're going to talk about the proper way to remove and replace a rear wheel anti-lock brake sensor on a late model Ford Explorer. In this step, we're going to talk about the proper way to check the continuity of the wiring from your anti... Read More »
Hello! This is Ross on behalf of expertvillage.com. That is my kitchen door and it is dark outside, it really doesn’t matter I cannot see the garage door anyhow if it was light out because it is blocked by the wall here. I did have to get up to... Read More »
In this clip, we're going to talk about the proper way to remove and replace a rear wheel anti-lock brake sensor on a late model Ford Explorer. In this step, we're going to talk about the proper way to re-connect your rear wheel anti-lock wheel speed... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip we'll be locating our power shut off. Before we can start taking down our old light we need to make sure that the power is shut off so we don't get electrocuted. The first thing we need to... Read More »
I'm Chad I present motorcycles in Wilmington, North Carolina on behalf of expertvillage.com I'm here to show you some of my maintenance on our bike before you go out for a ride. Now we are going to talk about some of the tools that we use today that you... Read More »
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Adding a light switch.... truebaca Electrical 6 07-18-2007 05:42 PM
adding 3-way switch to existing circuit msahaydak Electrical 4 02-18-2007 01:43 AM
detached garage Kapt Electrical 12 01-17-2007 09:37 AM
Best way to insulating a heated detached cement block garage Joe Nulph Building & Construction 1 03-06-2006 11:30 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
