#1 |
detached building subpanel 3-wire questions
first, what constitutes a "detached" building? my garage (and a small guest apt) is physically attached via a breezeway of nearly 20'. is it, by NEC definition, a detached or an attached building?
the garage has a subpanel fed by a 3-wire cable (2 hot, 1 gnd) which, in turn, is connected to the main subpanel in the house. from the discussion in a previous thread this seems to be legal prior to the 2008 NEC *if* the garage is a detached structure. however, i question the fact that the gnd of the cable is connected at the main subpanel rather than at the main panel itself. i think it should be ok but what say you? fwiw, the house was build in the late '50s. thanks peyton |
#2 |
It's an attached garage; you run the calbes through the breezeway roofed ceiling.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. |
| Display Modes | |
| Detached Garage Sub Panel Questions | smuth10 | Electrical | 8 | 10-11-2010 12:24 PM |
| Progress on Storage building, more slab questions. | J S Machine | Building & Construction | 18 | 05-07-2010 08:30 AM |
| installing a subpanel from 10/2 wire. | d_skutnik | Electrical | 7 | 10-08-2008 06:35 PM |
| Subpanel questions | wease | Electrical | 1 | 12-07-2006 02:39 PM |
| running wire questions | jude | Electrical | 4 | 12-01-2006 01:41 AM |
