Detach Building Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 08:51 PM   #1
Detach building wiring question
I have a feed from main panel to a sub panel in my house and a sub panel in a detached workshop. Can I add 1 circuit and wire from workshop sub panel to another detach storage building? I don't plan to plan to add another sub panel there since this wire will only feed 1 light bulb and 2 outlets. Do I have to GFCI protected this circuit?
Also, I found that the sub panel in the workshop use ground wire which comes from main panel. Do I have to put additional ground rods for this detach workshop?
Thanks in advance.
thone is offline   Reply With Quote
Old 09-22-2011, 03:05 AM   #2
Code05's Avatar
Rewards Points: 1,104
GFCI for receptacles-yes.
For one branch circuit, rods-no.
Code05 is offline   Reply With Quote
Old 09-22-2011, 05:18 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
Ground rods:
The outbuilding fed by one circuit: No rods needed.
The detached workshop with a sub-panel: Yes ground rods needed (in addition to the ground wire that runs with the power wires back to the panel that feeds it).
Kyle
Old 09-22-2011, 05:33 AM   #4
Code05's Avatar
Originally Posted by SD515 View Post
Ground rods:
Good catch , I missed that question.
The Following User Says Thank You to Code05 For This Useful Post:
SD515 (09-23-2011)
Building my own pendant light. Basic wiring question. wonderand Electrical 1 08-07-2011 05:50 AM
Wiring question fabian Electrical 7 07-28-2011 03:31 PM
Question about series wiring. Chevyman30571 Electrical 7 02-26-2010 08:54 AM
question on storage building B In SC Building & Construction 4 01-11-2010 01:15 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
