Delta Table Saw Trips GFCI - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 06:40 PM   #16
The starting capacitor does not increase or decrease the amount of current flow, it does however cause a time shift in the flow from the hot to the neutral and the neutral to the hot. The time shift means that at a given time the current flow on the hot is different than the current flow on the neutral. A difference of current flow between the hot and neutral side is what causes the GFCI to trip.
hayewe farm is offline   Reply With Quote
Old 04-10-2010, 05:37 PM   #17
For troubleshooting purposes you could try running the saw from the GFCI through a #14 or #12 extension cord. This should reduce the startup surge somewhat.
For a 15A saw and a 5% voltage drop at 120v max lengths would be 75' and 125', respectively.
New Fluorescent Ballast trips GFCI Breaker?? marc515 Electrical 7 02-18-2010 04:42 PM
GFCI Trips campbellpt Electrical 28 11-21-2008 03:06 PM
GFCI intermittent nuisance trips jejm1975 Electrical 43 09-07-2008 09:18 AM
Delta table saw blade guard problem RDS Tools 7 03-07-2008 03:29 PM
GFCI Trips Overnight Jomby Electrical 5 12-13-2007 10:41 PM
