Deleting A Whole Circuit. Ok To Leave Romex Disconnected In-wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2011, 05:45 AM   #1
Deleting a whole circuit. Ok to leave romex disconnected in-wall?
I am removing all the in-wall circuits in my garage and changing to surface circuits.
I want to delete all outlets, switches, & light fixtures.
I want to patch drywall over the old boxes.
I understand that it is against code to do that with live circuits, they must have an access. But for a de-energized wire is it OK to just cut it off and patch the hole? On the breaker side of the wires I would remove from panel and cut them as short as possible so it would be real impractical to reconnect to the subpanel.
Thanks for any help!
red_3000 is offline   Reply With Quote
Old 04-22-2011, 07:48 AM   #2
I ask the impossible!
Rewards Points: 640
This is common practice when knob and tube is upgraded, and it should be fine with romex.
The new wiring will likely have to be done to current code of course, most notably meaning GFCI.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Can I run romex across garage wall? heyd Electrical 2 08-25-2010 10:21 PM
Installing a touch-lamp circuit in a wall - please help.... azirkin Electrical 3 07-01-2010 10:09 PM
Black and white romex for 220v circuit? NateHanson Electrical 2 05-02-2007 05:43 PM
