Delete Switch To Control Outlet Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 10-15-2010, 04:30 PM   #1
delete switch to control outlet receptacle
not sure i'm asking the right question in the right place here.
what i'm trying to do is remove a toggle switch that controls an outlet receptacle so that i have continuous power to the outlet.
the toggle switch is one of three in the box, thus i'm also having difficulty locating a wall plate that has 2 toggles(on the right) and one blank(on the left).
i was thinking i could eliminate the toggle switch by hardwiring the outlet, then possibly just put the switch back in the box so that it's a dummy switch and doesn't look too shabby.
anyone with do's or don'ts on this please let me know.
thanks in advance!
constantinus is offline   Reply With Quote
Old 10-15-2010, 04:36 PM   #2
Mad Scientist
Most home improvement stores should have modular wall plates. They are assorted plate sections that snap together to form a custom plate. I've used them for exactly this; I installed a three-gang switch box in my garage, and then decided to only add two switches.
McSteve is offline   Reply With Quote
Old 10-15-2010, 04:45 PM   #3
oh good to know, i was trying to find a one piece wall plate but a modular plate just might be the solution.
any idea about wiring of the outlet to bypass the switch?
i'm assuming it's just connecting the proper wires and it should be good to go.
thanks again for the response!
Old 10-15-2010, 04:46 PM   #4
Mad Scientist
Well, your absolute easiest way is just to take the two wires off the screws on the side of the switch, and wirenut them together.
Old 10-15-2010, 04:49 PM   #5
that's exactly what i planned to do.
just wanted to get a little reassurance i was doing the right thing.
thank you kind sir!
Old 10-16-2010, 12:43 PM   #6
Licensed electrician
Rewards Points: 1,258
Certain rooms are required to have a switch controlled receptacle or lighting outlet. Removing the switch may create a code violation.
New outlet using power from a nearby switch. surecook Electrical 23 10-16-2009 07:27 PM
Half outlet / Half switch tb582 Electrical 3 10-01-2009 09:55 PM
Wiring an Outlet From a Two-Way Switch lburriss Electrical 3 07-07-2009 09:06 PM
Tracing light switch to an outlet allanet Electrical 13 04-03-2009 09:44 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
