-   -   delete switch to control outlet receptacle (http://www.diychatroom.com/f18/delete-switch-control-outlet-receptacle-83998/)
constantinus 10-15-2010 04:30 PM
not sure i'm asking the right question in the right place here.
what i'm trying to do is remove a toggle switch that controls an outlet receptacle so that i have continuous power to the outlet.
the toggle switch is one of three in the box, thus i'm also having difficulty locating a wall plate that has 2 toggles(on the right) and one blank(on the left).
i was thinking i could eliminate the toggle switch by hardwiring the outlet, then possibly just put the switch back in the box so that it's a dummy switch and doesn't look too shabby.
anyone with do's or don'ts on this please let me know.
thanks in advance!
McSteve 10-15-2010 04:36 PM
Most home improvement stores should have modular wall plates. They are assorted plate sections that snap together to form a custom plate. I've used them for exactly this; I installed a three-gang switch box in my garage, and then decided to only add two switches.
constantinus 10-15-2010 04:45 PM
oh good to know, i was trying to find a one piece wall plate but a modular plate just might be the solution.
any idea about wiring of the outlet to bypass the switch?
i'm assuming it's just connecting the proper wires and it should be good to go.
thanks again for the response! :thumbsup:
McSteve 10-15-2010 04:46 PM
Well, your absolute easiest way is just to take the two wires off the screws on the side of the switch, and wirenut them together.
constantinus 10-15-2010 04:49 PM
that's exactly what i planned to do.
just wanted to get a little reassurance i was doing the right thing.
thank you kind sir! :)
Jim Port 10-16-2010 12:43 PM
Certain rooms are required to have a switch controlled receptacle or lighting outlet. Removing the switch may create a code violation.
