Delay When Turning On Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 08:20 PM   #1
Delay when turning on light switch
Hello there,
I just installed a new fixture in my dining room. It has 5 MR16 halogen bulbs. When i turn on the light switch, the lights are gradually turning on to full brightness. The process takes a between 5 to 10 seconds.
I removed one of the bulb and noticed it took a bit less time and continued until I had only 3 bulbs and then the lights are turning on instantly.
So I think its obvious that the fixture is drawing too much power from the circuit. My question is, why? What tests can I dk to find the cause? Is it a faulty switch or faulty wiring?
Thank you!
Kalquaro is offline   Reply With Quote
Old 04-30-2012, 08:44 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Are you sure they are MR16 Halogens? They do make MR16 compact florescent equivalents now.
ie
Old 04-30-2012, 09:09 PM   #3
No I confirm they are halogen lights and not CFLs.
I am wondering if LED bulbs would fix the issues since they draw much less power than halogen lights. And if it was a wiring issue, the breaker would trip wouldn't it?
Old 04-30-2012, 09:14 PM   #4
k_buz's Avatar
It has nothing to do with the wattage of the lights.
Old 04-30-2012, 09:24 PM   #5
Then what does it have to do with?
Actually i just tried turning it on again and now it wont. I can hear a clicking sound and the lights flickers very weakly. I left it like that for a like 30 secoknds and turned the switch off. There really might be a wiring issue after all I guess.
When I installed it, there was 3 sets of wires. 2 black wires twisted together, 2 white wires twisted together, one red wire and the ground wire. BTW, I'm located in Canada,if that makes any difference in the electrical code.
I used the set of white wires and the red wire to connect the power to the fixture and i also connected the ground wire to the fixture's frame.
Old 04-30-2012, 09:26 PM   #6
k_buz's Avatar
It sounds like you wired it correctly. Double check the splices and make sure the lamps are in the sockets completely.
Are these 12V MR 16s or 120V MR 16s?
Is it on a regular switch? or a dimmer?
Old 04-30-2012, 09:35 PM   #7
I will double check everything tomorrow. This particular fixture took me 2 and a half hours to install so im not looking forward to taking it apart again lol
Thats said, the bulbs are 12V, 35 Watts and it's a regular switch.
Old 04-30-2012, 09:38 PM   #8
k_buz's Avatar
That means there is either a transformer integrated into the fixture, or one is needed to be installed for the fixture.
It is possible that the integrated transformer is bad. If you are going to take it down, you might want to exchange it right away.
Old 05-01-2012, 02:21 AM   #9
" Euro " electrician
frenchelectrican's Avatar
The other possiblty that you may allready overload the transfomer if this is a low voltage verison so you may want to read the transfomer info and it will tell you what the max wattage or amp on secondary side ( aka low voltage side ) if you go over the limit they can overheat or shorten the life pretty fast.
Merci,
Marc
Old 05-01-2012, 06:40 PM   #10
Problem is fixed!
Turns out that the shop where I bought my fixture sold me 35 W bulbs when the maximum capacity for the fixture is 20W bulbs. I replaced the bulbs and it's now working normally.
The Following User Says Thank You to Kalquaro For This Useful Post:
frenchelectrican (05-02-2012)
Old 05-02-2012, 12:27 AM   #11
That is the key issue you have to double check the luminaire max wattage rating I know it can happend with any type of luminaire so always double check the wattage rating on them.
At least now you know why it act up in first place.
Merci,
Marc
Turning OFF light switch causes AM radio interference ? gcmackinnon Electrical 4 10-19-2011 12:03 PM
Ceiling Fan and Light Switch Problem desiboy Electrical 3 03-03-2011 12:09 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
