Delay Light After Flipping Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 11:20 AM   #16
zpm
yeah, right
From personal experience with Hunter fans, just remove the stupid control box in the fan housing. Couple of snips, couple of small wirenuts, problem solved.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
The Following 2 Users Say Thank You to zpm For This Useful Post:
afdad922 (03-26-2011), pyper (03-25-2011)
Old 03-26-2011, 12:39 AM   #17
Current limiter device
I believe this is the problem. All connections are tight and there are separate switches for light & fan.
Originally Posted by kbsparky View Post
Please be advised that many ceiling fans now incorporate a current-limiting device in them to prevent the use of too-large light bulbs in their light kits.
This can cause a slight delay in the light working once power is applied.
Normal operation, no testing or repairs are needed.
afdad922 is offline   Reply With Quote
Old 03-26-2011, 12:42 AM   #18
No loose connection found. Think there is a delay in the current limiter device.
Old 03-26-2011, 12:45 AM   #19
two separate switches. Think the current limiter device now in the light circuits causes a delay.
Old 03-26-2011, 08:48 AM   #20
Rewards Points: 506
<img src="http://www.diychatroom.com/attachment.php?attachmentid=31230"/>
Did you wear rubber-palmed gloves when you did this?
jlmran is offline   Reply With Quote
Old 03-26-2011, 08:53 AM   #21
Electrician
SD515's Avatar
Rewards Points: 504
Kyle
Old 03-26-2011, 11:34 AM   #22
zpm
yeah, right
No, I wore my arc flash gear.
Old 03-29-2011, 01:41 PM   #23
Consultant
HGRBS's Avatar
Rubber-palmed Gloves
What are the rubber palmed gloves for?
Hi jlmran,
Normally, we try not to spend much time in forums.
Just the same, rubber-palmed gloves are rugged cloth knit gloves having a durable, rubber coating from the bottom of the palm side of the glove to just a bit up and over the thumb and finger tips.
They're used a lot in gardening, warehouses where lots of boxes are being manually shifted around, and when handling things which are difficult to keep a grip on.
Aside from gardening, these gloves are primarily used for gripping items which otherwise may be a bit more difficult to manage.
When we're working overhead, especially with light fixtures or anything with smooth surfaces, there's a lot of lifting, lowering, raising, and shifting activity.
In these cases, your palms and fingers naturally perspire. As a result, whatever you're trying to adjust, replace, lower, raise, etc...become less manageable. Without rubber-palmed gloves, you'd find yourself regularly pausing to wipe the perspiration from your palms and fingers in order not to smudge or to enable you to get a better grip on what you're working on.
This is especially so during the summer months.
Also, if you're using manual hand tools, these gloves provide more leverage, especially if what you're working on requires more than the normal degree of force to be loosened or to be broken loose.
They're also a form of safety protection around household electrical circuits which may have faulty shut off mechanisms or loose wires which may be part of a cluster, running parallel to a completely different outlet.
Electrical outlets aren't always connected the way we think they should be...especially, in older homes. Better to be safe than sorry.
Finally, we, at HGRB Services believe that you, as the homeowner/homerenter want to complete your projects as affordably, as conveniently, and as safely, as possible. Always wear safety glasses or safety goggles over your prescription glasses when you're doing anything overhead. Always wear the right sort of gloves for the job.
Nothing like a light fixture or the blade of a ceiling fan you're trying to install or remove, suddenly slipping through your hands, along your arm, and into your eye.
What we think is highly unlikely to happen, is what likely does because that's what we think.
HGRBS is offline   Reply With Quote
Old 03-29-2011, 03:07 PM   #24
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Originally Posted by HGRBS View Post
Hi jlmran,
No wonder consultants charge so much It takes then 200 words to describe a simple task (and someone has to pay for them words).
Coastal South Carolina
rjniles is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 11:18 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 06:35 PM
