Delaware Adopts 2011 National Electrical Code® - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2012, 06:50 PM   #1
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
The Delaware State Fire Prevention Commission adopted the 2011 National Electrical Code (NEC®), effective December 11, 2012. This regulation has the force and effect of law in the counties, cities, and political subdivisions of the State. However, any county, city, or local jurisdiction can amend this regulation providing such regulation or ordinance is more stringent or imposes higher standards than those required by the 2011 National Electrical Code and are not inconsistent with the NEC and are not contrary to recognized standards and good engineering practices.
The 2011 NEC is adopted in its entirety with the exception of two amendments regarding the installation of smoke alarms on branch circuits protected by Arc-Fault Circuit-Interrupters. The amendments are the same as those made with the adoption of the 2005 and 2008 NEC. Sections 210.12(B) and 550.25(B) are amended by adding a second, third and fourth sentence to read as follows: Smoke alarms shall not be placed on branch circuits protected by arc-fault circuit interrupter. All smoke alarms shall be supplied by branch circuits dedicated to smoke alarm equipment. The connection of the smoke alarm branch circuit to the power service shall be mechanically protected by utilizing lock-on devices.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 12-05-2012, 07:12 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I understand that it says the smokes require a dedicated non-AFCI circuit, but what does the last sentance mean and how is it implemented?
Coastal South Carolina
Old 12-05-2012, 07:15 PM   #3
electures's Avatar
Breaker locks.
or
The Following User Says Thank You to electures For This Useful Post:
rjniles (12-05-2012)
Old 12-05-2012, 07:17 PM   #4
Licensed electrician
Rewards Points: 1,250
A breaker lock is placed over the breaker handle to prevent the circuit from being turned off.
Old 12-05-2012, 07:39 PM   #5
Rewards Points: 332
What prevents the lock from being removed?
sgip2000 is offline   Reply With Quote
Old 12-05-2012, 07:41 PM   #6
electures's Avatar
Nothing. It is just a deterant.
Old 12-05-2012, 08:28 PM   #7
Electrical Contractor
kbsparky's Avatar
You'll flunk your final inspection in Delaware without that breaker lock on the smoke circuit.
I really don't agree with it, but have to comply if I want to work there.
-KB
Old 12-05-2012, 08:50 PM   #8
The fact that is is a dedicated circuit makes it easy to live without it. I think this is a mistake on the part of the Delaware code officials.
Old 12-05-2012, 08:52 PM   #9
Rewards Points: 332
That was my thinking as well.
Old 12-05-2012, 10:17 PM   #10
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
No homeowner will have a screwdriver small enough to loosen the screw...its all good.
Old 12-05-2012, 11:17 PM   #11
Rewards Points: 258
i don't believe that. I think the intent of the lock is so that home owners don't turn it off while doing other work. keep the home owner protected from them selfs
redman88 is offline   Reply With Quote
Old 12-06-2012, 05:46 AM   #12
A "Handy Husband"
rjniles's Avatar
I think K_Buz was speaking tongue in cheek.
I always thought having the smokes on a lighting circuit was a better deterrent to keep people from leaving them turned off. But the code says different.
Old 12-06-2012, 06:54 AM   #13
Pure Genius
Rewards Points: 150
Here in OH we have to put the smokes on a bedroom circuit.
Dierte is offline   Reply With Quote
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 04:19 PM
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 11:04 PM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 12:12 PM
