Definition Standby Power Vs Emergency Power - Electrical - DIY Chatroom Home Improvement Forum
Old 09-05-2008, 04:02 PM   #1
oops, did I do that!
Definition standby power vs emergency power
Is there a clear definition of the difference between standby power, which would not include life safety, and emergency power which would include life safety? Do both include life safety?
Where in the NEC 2005 would I look?
8 Ball is offline   Reply With Quote
Old 09-05-2008, 10:55 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
No both do not include life safety. emergency power and it's descriptive definition are found in Article 700.
As for the generic term ' stand-by power ' generally refers to systems designed to aid emergency personnel in the event of fire or catastrofic event when normal utility power is interrupted but not intended for life safety. An example would be Article 701 "legally required standby-systems."
Old 09-06-2008, 05:19 AM   #3
Thank You for your response.
Lighting would be life safety, unquestionably, a fire pump or elevator would be also if determined by the local authority, or NFPA is that correct?
If I have a branch circuit to an emergency lighting panel, and found that the extra slots were being used for UPSs by IT people, would that be a violation of NEC 5000, 700.15?
Last question, It seems to be a standard that generators should only be loaded to 80% of thier full load capacity. Where do I find the code that would stipulate that?
Thank You.
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
Debugging Hot Water Heating System when on Standby Power hwitten Electrical 4 12-15-2006 08:47 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
