Definition Of "rough Electrical" - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 09:05 PM   #1
Definition of "rough electrical"
Would anyone have a definition or be able to point me to a definition of "rough electrical" I am in the process of a basement remodel. I have the electrical permit, and honestly a very responsive inspector, he answers my email same day i send. But i figured its not his job to teach me defninitions and alot of other things. Other than go read the code, is there a resorce i could referenc to determine what the technical definition of "rough electrical" is? Or is it clearly defined in the 2011 NEC. and yes that is the specification i must meet. Although there is a little bit of lee way i think on the arc fault protection.
thanks
bf514921 is offline   Reply With Quote
Old 07-12-2012, 09:16 PM   #2
Rewards Points: 334
I'm sure a pro will be around, but I would ask the inspector to confirm. When I did my addition, rough in was defined as running the wire to the boxes and clamped properly, but no devices connected. No dry-wall installed so he can see it is properly ran, drilled through 2x4's, stapled etc. Things like outlet spacing would be looked at too.
Here is one link:
http://www.jamescitycountyva.gov/bui...ctric-res.html
tribe_fan is offline   Reply With Quote
The Following User Says Thank You to tribe_fan For This Useful Post:
andrew79 (07-12-2012)
Old 07-12-2012, 09:24 PM   #3
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Rough in electrical is installing the boxes and the wires. This needs to be inspected prior to insulating and closing in the walls with drywall or other covering. Tribe Fan said it well.
Finish or trimming out is installing the switches, fixtures, and receptacles.
John
jrclen is offline   Reply With Quote
Old 07-12-2012, 09:26 PM   #4
Rewards Points: 1,192
I'm with tribe fan,everything is ready to board up for finish.Wires tied through and grounds bonded to boxes.
bobelectric is offline   Reply With Quote
Old 07-12-2012, 10:58 PM   #5
thanks for the responses i appreciate it, so would i need al my can lights installed and wires hanging out? i wil have strain relief connectors on the boxes.
Old 07-12-2012, 11:26 PM   #6
k_buz's Avatar
Rewards Points: 2,006
Strain relief connectors, or just connectors?
There would be no need for a true strain relief connector.
The Following User Says Thank You to k_buz For This Useful Post:
Old 07-13-2012, 01:47 AM   #7
Sparky
Rewards Points: 510
Rough electric is everything that has to be done before drywall. Boxes mounted, wire pulled, strapped. Some inspectors want grounds made up as well
Techy is offline   Reply With Quote
Old 07-13-2012, 06:28 AM   #8
techy - , so would this mean then i would have to have my can lights installed and wired, witht he little door haging open?
k_bux - Strain relief, i know its over kill but hey, i am sure the wires wont move. Plus i though i read some regulation on spans of unsupported wire and strain relief connector, however i could be wrong.
Old 07-13-2012, 07:27 AM   #9
Sparky
Rewards Points: 510
I usually have the doors closed, if the inspector wants to look at the can he'll ask you to open one
Old 07-13-2012, 09:37 AM   #10
jrclen's Avatar
Rewards Points: 514
The can lights will be completely wired during rough in. I don't leave covers open.
I'm not sure what you mean by strain relief. If your doing it in romex you will need staples.
John
Old 07-13-2012, 11:16 AM   #11
Licensed electrician
Rewards Points: 1,266
I think someone was just saying strain relief conectors would not be required but that regular cable connectors were fine.
Old 07-13-2012, 08:37 PM   #12
thanks for the info guys. jrclen, the strain reliev is for at the box for the can lights. something like this. http://www.grainger.com/Grainger/RAC...K50?Pid=search It sprobably overkill but ohwell.
staples for normal wire suppoert
Old 07-13-2012, 10:29 PM   #13
jrclen's Avatar
Rewards Points: 514
Okay, that is a normal romex connector. They work great.
John
Old 07-15-2012, 12:22 PM   #14
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
thanks
Please check out post #13 in this thread. This is what most inspectors I know as well as myself preferr seeing.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-15-2012, 08:14 PM   #15
thanks electures
Anyone see a problem with this definition of Normally Open? justplumducky HVAC 11 09-05-2011 11:38 AM
Definition of wet location lyle jessee Electrical 1 07-01-2011 09:57 PM
Damp Location Definition Steve Burke Electrical 8 03-03-2011 10:58 AM
Definition cybervex General DIY Discussions 7 09-09-2008 06:34 PM
Definition standby power vs emergency power 8 Ball Electrical 2 09-06-2008 06:19 AM
