Define Conduit Hanger - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2010, 01:57 PM   #1
Define conduit hanger
I started running the pvc conduit for my subpanel. The question is what qualifies as a conduit hanger? Its not feasable for about 15 feet for me to use conduit clamps but the only solution for the 15 feet is metal strap like plumbers use for hanging pipe. Is this against code? The conduit is 1"pvc hung horizontally in a hard to access area between 2 ducts.
Also where the conduit enters the load center, i had to use a metal lock nut on a pvc fitting because the store didnt have any pvc ones. is this ok?
1982shawn is offline   Reply With Quote
Old 12-28-2010, 02:38 PM   #2
Just call me Andrew
Rewards Points: 1,020
I am no electrician, but I always use metal locknuts on PVC male adapters.
And I can't see a problem using metal straps to hang conduit. If you're worried, use plastic strapping, should be right next to the metal stuff.
Andrew
secutanudu is offline   Reply With Quote
Old 12-28-2010, 03:33 PM   #3
this is what i need to know if its okay?
Old 12-28-2010, 04:58 PM   #4
Rewards Points: 1,448
That metal strap will work fine.
Old 12-28-2010, 05:05 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
metal locknuts are what you use
to the strap; I am sure I could find you a proper hanger. The plumbers strap will likely be ok unless you have a real hardcore inspector. He could shoot it down as it is not "listed for the purpose" and in a real strict definition, that purpose would be to hang electrical conduit.
what you could do it attach a "minnie" to the strap and attach the strap up wherever you are planning on attaching it.
http://minerallac.thomasnet.com/viewitems/l-categories-minerallac-conduit-cable-wire-condu-3/ries-minerallac-conduit-cable-wire-conduit-hange-4?&bc=100|1091372
there are many other possibilities as well.
Old 12-28-2010, 05:47 PM   #6
Nap, thanks ill just use the minnies with the flat side down.
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 06:56 PM
How to plug unwanted and leaking conduit? gernith General DIY Discussions 6 08-08-2010 01:09 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 02:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 06:25 PM
